Interior trim rattle
04-29-2012, 06:17 AM | #3 |
Rep 2,431
No, but you may want to check to fit of your trim pieces.
My speeding isn't the problem. It's the Slow Folks ahead of me that cause accidents!
05-01-2012, 10:49 AM | #4 |
Rep 1,268
My trims pieces definitely "pop" on the passenger side. Tried searching for a solution to nothing really. Do you know of a good fix?
Past: BMW (22 G20 M340i, 15 F80 ///M3, 12 E92 335i, 08 E90 335i, 02 E46 325i)
Mercedes-Benz, Porsche, VW, Lexus Present: 24 992 C2 |
05-01-2012, 11:20 AM | #5 |
Rep 1,783
I don't know if you have this but check your EZ-pass. The sound was bouncing off the dashboard, almost went to the dealer for it.
Koni special active red, eibach pro-kit springs, Remus exhaust, stage 3 intake manifold,Stage 2 AA tune, BMW Short shift kit. Silicon intake pipe. M3 control arms front, M3 rear. ECS trailing arm with whiteline bushings. Purple powerflex subframe bushings. Yellow power flex upper shock mounts. Single mass flywheel OE weight.
05-01-2012, 04:41 PM | #6 |
Rep 2,431
Normally cleaning and using a good protectant will keep them from squeaking or making other noises. Check the car care section for more info.
05-01-2012, 11:27 PM | #9 |
Resident Car Audio Guru
Rep 597
I have developed rattles in a few places. The roll bar covers have warped, so I removed them, covered the roll bar in closed cell foam (HushMat brand), then filled the spaces between butresses with HushMat. Fixed that one. Then I noticed the ski pouch covers rattle horribly...they're coming off next.
This is the one that really gets me, though: The left front fender has delaminated, and has a nasty rattle now. I've ordered some 3M 8115 panel adhesive to fix it, but has anyone else heard of this one? |
05-02-2012, 09:46 AM | #10 |
Rep 103
I've actually found that I have a rattle that comes from the passenger seat's headrest adjustment ring. It's slightly loose and rattles until I push it back in a bit. If you hit the seat with your hand, you should be able to tell if there's a rattle coming from somewhere. I also have a rattle in my center dash if I hit that as well, but it comes and goes.
05-02-2012, 09:51 AM | #11 |
Rep 676
i had the rattle in mine (center console area), then it stopped once i put vinyl on all the trim pieces. now VERY quite like new
// JB4 ISO // Running Meth // Full FBO // E85 user //
05-02-2012, 12:45 PM | #14 |
Rep 3,730
My car was rattle free until I added downpipes and a dp back exhaust
Glovebox and pillars were the two biggest culprits.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
05-02-2012, 03:39 PM | #15 |
Rep 107
I have squeaking in my BMW, but no popping yet.
2006 BMW 325xi | My Personal Garage |
05-02-2012, 03:44 PM | #16 |
Rep 221
How does it run? It's always a liquid. They make foam applicators on top of the bottle and you just rub it on. It's impossible to put too much with the foam applicators. I actually find they dispense too little.
05-02-2012, 03:59 PM | #17 |
Rep 597
when they hit about 140F the compounds start to separate. By 200F you have stuff running down the rubber. Not sure where you are, but around here we have to think about that. When it's 120 outside, and you park in the sun, underdash areas can easily reach 185 in an hour
05-02-2012, 09:24 PM | #18 |
Rep 426
i tried using a piece of felt between the A pillar and dash board on passenger side which eliminated the that rattle, only to find out had the same rattle on the driver side (which I fixed through the same method for now). Now I noticed that theres one coming from the rear driver side door pull which is really annoying, + theres no obvious way to tighten or isolate the rattle there. The radio is the best solution...
05-02-2012, 10:54 PM | #19 |
Rep 46
I found the solution to my major rattle online somewhere. I had a major rattle fromo behind the radio...a metal type rattle. I inserted a piece of 1/4" hard rubber hose sideways into the gap between the center console and the bottom of the radio/AC control panel. Put it another way...if you look at the most forward part of the center console...you'll see it goes under the bottom of the radio/AC panel. I just sqeezed the hose in that gap on both the right and left side...problem fixed.
Just thought I'd mention it...something to try. |
05-03-2012, 04:21 PM | #20 | |
Rep 597
05-03-2012, 04:28 PM | #21 |
Came to the N55 Darkside
1115
Rep 12,740
Got a rattle in the middle of the cabin under certain acceleration. I have a clunk that sounds like a broken shock toward the back left part of the cabin too. Just got used to it.
When the top is down it doesn't even matter |
05-03-2012, 04:33 PM | #22 |
Rep 11
Tags |
a pillar, e90, fix, noise, rattle |
