HELPP!!! white smoke from engine bay
05-01-2012, 07:41 PM | #1 |
Rep 10
Hi all,
I have a 2006 320i e90 which has just started to pour smoke from engine bay after being driven for 5 minutes or...I have always had a minor obvious oil leak from the rocker/valve cover gasket which I noticed through the burnt candle smell through the AC. I have taken it to a mechanic and he believes that they need to replace the brake vacuum pump, rocker cover gasket, oil filter housing gasket and fronmt engine solenmoid seals? I want to know if this is indeed the case? The smoke is white and does have a slightly different smell to that of the oil (but maybe its just me). I am startignt o notice that the coolant levels are also going down. Could this be a coolant leak somewhere which is causing the large amount of white smoke (embarrassing to drive)? Please note that their is NO smoke coming from the exhaust... |
05-01-2012, 07:45 PM | #2 | |
Rep 3,915
Drives: 330i, 135i
05-02-2012, 08:42 AM | #3 | |
Rep 3,606
05-02-2012, 09:36 AM | #5 |
Rep 413
05-03-2012, 01:54 AM | #6 |
Rep 10
Thanks mate - how bad was the smoke from the leak from radiator to housing? How much did it cost to fix?
05-03-2012, 10:21 AM | #7 | |
Rep 413
What side of the engine bay is smoke coming up from. this can give you an idea of what hose or part it is leaking at. |
05-03-2012, 08:24 PM | #8 |
Rep 10
thansk for your reply - that sounds very similar to what it is only - there is no sign of leakage (liquid) around the coolant expansion tank.
the smoke actually looks to be comign from the under the rocker cover! Would this be common with a rocker/valve cover leak? |
