6MT Owners: Randomly not able to go back to 1st gear?
05-03-2012, 09:45 PM | #1 |
Anti-Fanboy
68
Rep 572
Hello everybody,
I'm a semi-new owner of an '07 335i E92 6MT. LOVE THE CAR! However, I've had to deal with an annoyance that I've seen documented on here and other BMW forums: Every once in a while, I'm not able to go into 1st gear, or it only goes in partially. It is truly random, as it happens whether I've been driving the car for 20 secs or 5 hours. I thought considering the mileage (closing in on 60,xxx miles) to change out the transmission fluid and replaced it with Royal Purple. This had absolutely no effect. I've found that there are others who have the exact same issue. Can anyone recommend a solution? P.S. I haven't had any problems engaging in any other gear, just 1st. [Edit]I take that back .. sometimes it's hard to engage reverse as well .. Last edited by Bunkei; 05-03-2012 at 09:59 PM.. |
05-03-2012, 09:53 PM | #2 | |
"J" BONE
24
Rep 578
procede v5 rev3, afe dual cone intake, full catless exhaust with muffler delete, hm style carbon fibre lip, 235/35/19,275/30/19 satin black linea corse818, H&R sport springs, Vishnu charge pipe with forged diverter valves, matte black kidneys, mtec superwhite angel eyes and fogs, bms cdv ER fmic, VRSF coated DP. Vishnu pwm meth kit
05-03-2012, 09:58 PM | #3 |
Anti-Fanboy
68
Rep 572
Yes, I learned that too, but this happens even when I'm at a dead stop. If I'm in neutral (because I know I'll be sitting for a bit), and then go into first. Sometimes it doesn't go in at all or just partially. If I step off the clutch in neutral and step back on, I can go in. Even then, sometimes it's a challenge.
05-03-2012, 10:03 PM | #4 |
Rep 409
Rev match for first, double clutch for reverse.
'08 335xi (E90), 6MT, Arctic/Black, ZPP, ZSP (18"s), ZCW, CA, PDC, i-Pod
Ordered-March 7, 2008, Shipped via Graceful Leader-March 21, 2008, Arrived Port Hueneme-April 11, 2008, Delivered-April 21, 2008 |
05-03-2012, 10:08 PM | #6 |
MOE
214
Rep 2,530
yeah gears r odd
05-03-2012, 10:13 PM | #7 |
Anti-Fanboy
68
Rep 572
05-03-2012, 10:18 PM | #9 |
Anti-Fanboy
68
Rep 572
05-03-2012, 10:36 PM | #10 |
Rep 13,128
Are downshifting into first ?
Are downshifting into first, for engine compression braking?
I don't do that on any of my manual cars . Basically the only thing I use 1st for is getting started, or creeping along in traffic. Any comments on this? Redline D6 sure smoothed things out a lot. If you are having to force into gear try letting it out on the clutch first in neutral then trying again don't force it. |
05-03-2012, 10:39 PM | #11 |
Anti-Fanboy
68
Rep 572
No, I use the brakes to stop the car. If I'm slowing to a stop, most of the time I come to a stop in neutral.
05-03-2012, 10:44 PM | #12 | |
Rep 1,157
This.
With varying degrees, every manual I have ever owned has done this. |
05-04-2012, 01:16 AM | #13 |
Rep 54
+1
TiAg 335i e90 LCI 6MT sport/prem/cold/xenon/logic7 Black/Black 330ci e46 5MT sport/prem/cold - retired, for sale! |
05-04-2012, 02:38 AM | #14 | |
Rep 6,606
05-04-2012, 07:50 AM | #15 |
Rep 3,606
05-04-2012, 07:51 AM | #16 |
Rep 6,606
05-04-2012, 07:55 AM | #17 |
Rep 86
I have a 07 335i E92 also, happens and is normal for a MT. You should try putting my 94' 5.0 Mustang into 1st, makes it seem like butter even at the worst in the BMW.
05-04-2012, 08:05 AM | #18 | |
Rep 2,118
To the OP: I have this happen once in a while on my MT 328. I just reclutch and the reengage first gear. It's just the sychro's not quite mating correctly. |
05-04-2012, 08:10 AM | #19 |
Rep 3,606
This is how rumors start. Who told you that and what was the reason? Find me 1 article/owners manual section that says that. I always give it a little throttle blip.
05-04-2012, 08:26 AM | #20 |
Rep 6,606
05-04-2012, 09:07 AM | #21 |
Rep 3,606
05-04-2012, 10:00 AM | #22 |
Rep 413
What I used to do when I had a manual when coming to a stop is clutch down, and as car is under 10mph, I just push the stick shift into first with little pressure but dont force it in and as car comes to a stop and find the right moment when the syncros are lined up, it just slips in. I dont do that all the time, usually when coming to 4 way stop. But like others have said, putting it in second then back to first helps.
Now for reverse, if it goes in partially, I put it in first gear then try reverse again and usually goes in. Another trick is when the gear is in partially in reverse, is to slowly release the clutch and as the car starts the move it will slide in fully. I've done it with every manual I've had and experience no problem. Once I started doing this, I've been doing it all the time. |
