Horn thoughts and suggestions please
05-04-2012, 05:23 AM | #1 |
Rep 218
I would like to upgrade the stock horn on my car. It seems a bit wimpy.
As much as I would like to go with the locomotive version just to see the fear that it strikes in the people who deserve a good blast, I will go with a more tame selection. I would appreciate your thoughts. What kind? Where purchased? Is it plug and play? Effective but not illegal. Thanks in advance.
ZPP, ZSP, NAVI, STEP, PADDLES, CA, PDC, HEATED SEATS, debadged, painted reflectors, plate frames, & keyhole cover, GP Thunders 8500 angels & fogs, Euphoria 6K High Powered Interior LED's, pearlescent E-brake handle, and mud guards, Split Second Turbo Tuner. |
05-04-2012, 11:01 AM | #2 |
Rep 1,450
I don't like the stock horn either, so I changed it right away. Before I traded my TSX to my new BMW, I removed the Hella horn that I installed. It's an easy install because BMW has two wiring terminals compare to my TSX (Japanese cars maybe only has one wire). That's why I didn't run extra wiring to connect to the battery. For BMW, all I did is fabricate a terminal that connects on both ends. I didn't remove the stock horn because I used it's brace to hold the Hella horn.
You will be pleased with the Hella Super Tone compare to stock horns. Go check the link where I posted a video after the install. http://www.e90post.com/forums/showth...la+horn&page=2
