Are the rear "side?" Panels the same in e92/93?
05-04-2012, 05:31 PM | #1 |
Rep 77
Hello, just picked up an e93, one of the panels has a mark on it. Im exploring a few options. Looking at junkyards or places where I may be able to pick up a panel. Do you guys have any ideas who I could contact?
So is the coupe/vert have the same (rear panel) Not sure the exact name, same place a door panel would be except in back..lol Other option was seeing if I could take it anywhere to be fixed? Im very anal and the texture would have to match 110% for me to be satisfied thoughts? |
05-04-2012, 07:30 PM | #3 |
Rep 1,346
Drives: 2011 E92 335 M-Sport
What year is your car?
05-04-2012, 10:19 PM | #4 |
Rep 77
07, after reading the manual i see those holes are for the wind deflector im guessing the coupes wouldnt have those :-/ that damn panel is probbaly $1000 new.. hm ill have to watch ebay and check some junkyards gonna be extra hard being vert tho
05-04-2012, 11:18 PM | #5 | |
Rep 1,346
Make sure of the part number, then either order it or look at a salvage yard or Realoem or ECS tuning or the onther 100 other places that will sell this: http://parts.bmwofsouthatlanta.com/s...ssembly=256165
05-04-2012, 11:44 PM | #6 |
Rep 77
was just looking at the same picture, found the piece for $114 @ http://www.trademotion.com/
Why is that going to be hard to install? The good thing is i only need black and not "red" and even better yet the thing is two pieces and eveeenn better yet! is coupe/ convertible IS the same panel lol Will make my search a lot easier! |
05-05-2012, 07:10 AM | #7 | |
Big Beaver Smile
2123
Rep 3,792
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
05-05-2012, 09:24 AM | #8 |
Rep 1,346
Agree, they're not the same.
05-05-2012, 11:32 AM | #9 |
Rep 77
thats odd, here is a direct link
http://www.trademotion.com/parts/200...iagram=1946790 It says " [ 1 ] BODY HARDWARE / QUARTER PANEL / INTERIOR TRIM / Upper qtr trim upper qtr trim COUPE, CONVERTIBLE, CONVERTIBLE, black Left PARTS: Order by description. MSRP Core ? Save Online Price $143.30 $0.00 $28.66 $114.64" usually wouldnt say coupe and convertible if it was only one or the other. am i reading something wrong? |
05-05-2012, 06:42 PM | #11 |
Big Beaver Smile
2123
Rep 3,792
You could be right. It seems odd that you'd have to drill in a plug, but I've seen weirder things. The coupe doesn't have a hole for it, and i just ran my hand along that panel to see if there was a notch under the "skin", but there weren't any.
05-05-2012, 07:46 PM | #12 |
Rep 77
that is really odd, i thought it would be more of a visible plug without the hole, because there are bolts inside the holes that i thought would be used in part to bolt the panel down do u have an 2011? ... I have a 2007, maybe the older ones have the plug in a coupe? hope someone else can chime in
05-05-2012, 09:14 PM | #13 | |
Big Beaver Smile
2123
Rep 3,792
05-06-2012, 12:10 AM | #14 |
Resident Car Audio Guru
Rep 597
that panel shouldn't take more than 30 minutes for a novice with basic knowledge of hand tools to remove and reinstall.
05-06-2012, 10:48 AM | #15 |
Rep 77
ill probably just suck it up and buy it new for the 114 so i dont have to look at it anymore, anyone know of any DIY for the panels? I dont like to just start yanking on stuff . I was kind of worried separating the top portion of it may be tougher then removing the entire panel it self
05-06-2012, 03:25 PM | #16 |
Rep 597
remove the rear seat bottom, remove 2 screws. Pull from bottom gently, but with firm pressure until you hear a POP. Then move on the the rest of the clips the same way. Pull the bottom out, then lift up to get it off the lip of the window frame.
05-06-2012, 04:18 PM | #17 |
Rep 77
ok thanks, i may have to PM you when i get the piece for help.. You have to remove the entire panel correct, then put on the new "top half" of it? is the top portion easy to separate ? i midswell order it now.
05-06-2012, 04:23 PM | #18 |
Rep 597
plastic welds hold the pieces together. they're easy to break, but you need something hot (like a soldering iron) to put them back on
05-06-2012, 09:55 PM | #19 |
Rep 77
ah not too crazy about that :-/ I think the damn whole panel is like $800 tho vs $114 for the top so I guess ill have to learn something on. So how would I break the plastic and still be able to use it with a soldering iron? Wouldnt I need more plastic,or hot glue or something?
05-06-2012, 10:31 PM | #20 |
Rep 597
if you are, in any way, mechanically able, you'll be able to figure it out.
