TMS 3.64 Diff?
05-05-2012, 04:53 PM | #1 |
Rep 4
TMS 3.64 Diff?
Has any one installed the TMS 3.64 diff? What are your thoughts on it. Worth 2k?
330i - Remus Quad Tip Exhaust, R-1 Body Kit, K&N airfilter, Bilstein Heavy Duty Struts -Mods to come -CDV delete and braided brake lines.
05-05-2012, 06:28 PM | #2 |
Rep 2,217
TMS = Turner Motorsport?
If that's what you're referring to, the actual brand they retail is "OS Giken" and yes, they are high quality limited/no slip differentials. NOTE: I don't currently have it installed, i just do a lot of research and have talked with people with that brand of LSD that all have positive things to say. -i hope this helps with your decision. |
05-05-2012, 07:05 PM | #3 |
Rep 611
I dont have one, but think it depends on your driving style.
Stock 330i MT gear is perfectly set for freeway crusing in 6th gear to take advantage of the 3 stage intake's powerband. 3.64 diff will offset the powerband in 6th when you are in 70-80mph highway crusing. however if you have a aggresive driving style, i think u will find it more entertaining. another mod u can try is the lighter flywheel, which i might eventually get once my clutch wears out.
N51- PI - PE - ESS Tuned - SSK - CDV Delete - AFE Header - B12 - Mfactory LSD
05-05-2012, 07:19 PM | #4 |
Rep 4
Yes the turner motorsport diff.... I have heard other things about the power band being messed up a bit in the high end. Should just increase the RPM's by a bit and be ok.
05-06-2012, 01:00 PM | #5 |
2006 330i, TSM, Black, manual, sport
880
Rep 3,699
Drives: '17 C2, GTI, Z4 3.0si Racecar
I don't know if an open diff with 3.64 gears is worth it for $2K
I have a Diffsonline LSD with 3.38 gears. This is totally worth it! Fantastic in the way you get traction all the time. It transforms the way you can drive your car much more aggressively (the LSD, not the gears). If you're going to do the upgrade, make sure you do an LSD also. Gearing alone will not get you the traction or enhance the driving experience. There are a couple of forum members that have 3.64 gears (do a search) and like it. Personally, I wanted more of a balance of driveability and performance. The 3.38 gears really gave me that balance. Acceleration is stronger and cruising on the highway is very forgiving (cruising at 70-75mph I average about 28.5mpg). On the track, it's a must have. I'm able to balance my car mid-turn the way it should be.
2017 Porsche C2 - manual of course
2015 GTI S 2008 BMW Z4 3.0si Coupe - because racecar |
05-06-2012, 03:26 PM | #6 | |
Rep 132
05-06-2012, 03:34 PM | #7 |
Rep 1,087
Drives: 2006 BMW 325i
Personally, if you aren't going to install an LSD, there is no point in changing differentials.
05-07-2012, 02:51 AM | #8 | |
Rep 611
what i mean "powerband" is that the 3 stage intake's first stage has peak torque around 2500-3100 rpm and that falls between 65-80mph in six gear. 3.64 will put you pass that range, 3100-3500 rpm is actually the transitional phases between first and second stage, which the torque band dip down a lot. its not that good to cruise in that range on the freeway in 6th gear.
05-18-2012, 11:26 AM | #9 |
Rep 4
I am palnning to do a LSD with the dif. Like you said no point to do it with out the LSD. I think 3.38 would do ok for what i am looking for. I just havent seen or heard of it.
