330i Transmission problem on switching back to 1st gear
05-14-2012, 01:53 AM | #1 |
Rep 137
The transmission on my 330i is having some strange problem every time when I come to a stop.....
When I'm about to stop the car (on D drive), I can feel a "push/ jumping" from the tranny when its downshift back to 1st and the whole car is "jumping" forward. I did the following test and determine the problem is on 2nd to 1st gear: >> when I drive on M mode, the car can stop smoothly and the gear will stay on M2 at complete stop.... once I switch from M2 to M1 manually (with brake apply) car "jump forward" >> car stop at M2.... switching from M2 back to D.... "jump" occur Does anyone know what happen to it and what is the solution to fix this..... is it a hardware or software problem ? Right now I try to avoid the Jumping by push to N right before stop or keep driving on M2 so the tranny wont go back to 1st on its own. Thank you and please offer advise... car info: 2007 330i / 43000km / change tranny oil 4 month ago but without changing the Pan/filter |
05-14-2012, 11:27 AM | #3 |
Rep 1,087
Drives: 2006 BMW 325i
Sometimes I can feel my torque converter unlock when Im slowing down, but Ive never had the car "jump". I cant help you on this one, my only suggestion would be take it in and get it checked out.
05-14-2012, 02:26 PM | #4 |
Rep 182
Drives: Black 2007 BMW 328xi
My car does this too 07 328 xi idk what it is one time the code came up for a shift solenoid but I've never seen it since
18" alzor style 703, 20mm rear spacers, 10mm front spacers, 235/40/18 Nitto Neogen, Afe Stage 2 pro5r CAI, Eurocharged tune, Meistershaft catback exhaust, 35% Window Tints, Taillight and Side Marker Tint, Debadge, Blackout Grille, CF Interior kit, Cyba Scoops
05-14-2012, 08:31 PM | #5 |
Rep 137
05-14-2012, 08:34 PM | #6 |
Rep 137
Some shop tell me to change the fluid + oil pan filter but I'm not too sure will that work. Also no code has ever appear so they may not found anything.
05-14-2012, 08:35 PM | #7 | |
Rep 287
thats my take on AT transmissions at least..... |
05-14-2012, 08:35 PM | #8 |
Rep 137
05-14-2012, 09:45 PM | #9 |
Cisco661
61
Rep 974
Drives: 2006 Monaco Blue 330I
how many miles did you have on car when you changed tranny fluid?
2006 330i/ Monaco Blue/ ZSP/ ZPP/ I Drive/ Burl Walnut Trim/ Steptronic/ Xenon Adaptives/ Logic7/ CF Mirror Caps/ Matte Black Grills
05-14-2012, 10:32 PM | #10 |
Rep 137
05-15-2012, 02:50 PM | #11 |
just another bmw douche bag
195
Rep 3,640
why would you change the trans fluid on the automatic at 39km? The auto trans is supposed to go around 100k miles (160,000km) without needing service. Some people do it around 80k miles, but 39,000km is way too early.
05-15-2012, 07:49 PM | #12 | |
Rep 1,203
OP, Do you have access to a Scan tool ? |
05-15-2012, 08:03 PM | #13 |
Rep 532
you cant mix old ATF with new, unless you flush within days
you need to flush your ATF again asap, and change your pan/filter REMEMBER TO USE OEM ATF...No redline, motual, r purple if you want to save your tranny Last edited by tc328; 05-15-2012 at 08:13 PM.. |
05-16-2012, 08:23 PM | #14 | |
Rep 137
05-16-2012, 08:29 PM | #15 | |
Rep 137
Not too sure did the shop drain out all the fluid 100% completely but even if there's old ATF there it should be not be a lot left...... may I ask why can't mix old ATF with new?? what is the reason behind it? thanks btw.... I did use OEM ATF but did not change my AT pan/filter last time. |
05-16-2012, 08:44 PM | #16 | ||
Rep 1,203
05-16-2012, 09:33 PM | #17 |
***** noob
1376
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
you never get it all out but flushing it then a pan/filter change can at least get you 85% new fluid. the torque converter and other listed can hold up to 3-4 qts. if you dont flush it then dont touch it at all
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
05-16-2012, 09:34 PM | #18 | |
Rep 137
I try to figure out is it possible for me to reset my tranny ecu and make it learn how to drive again.... I agree with you that unless it is a brand new tranny... there's no way one can drain out all the ATF.... anyway, a shop did tell me to change the ATF with oil pan/ filter to see if it can fix the problem. I'm not too sure will that work. Thanks again... |
05-16-2012, 09:39 PM | #19 | |
Rep 137
thanks.... |
05-16-2012, 09:48 PM | #20 |
***** noob
1376
Rep 10,479
things doesnt break down right away, 1 tiny particle can cause your tranny to slip, its a chain rection....heat will start to generate more and more over time
stop wasting time, i also recommend a pan filter change but it might be too late
2006 325xi (Sold)
03-19-2013, 02:47 PM | #21 |
Rep 10
Re:Transmission Issue
Hi Testdriver,
I've been searching every website to see if anyone else had this problem. My 328i sport does the same exact thing ! It kicks/jumps right as i slow down to the 10mph mark. Every time, I took it to the dealer and drove with a mechanic. It stopped doing it right then and there. As soon as I left the lot it returned and has gotten really bad, sometimes the whole car shakes. Have you figured out what it is yet? It's driving me crazy. |
03-21-2013, 09:19 AM | #22 |
Rep 39
Drives: F36 428i MSport Alpine White
Same symptom in my 05 325i. Try resetting the adaptation in INPA which will help. But it is just a matter of time this weird jump is coming back and then another reset will help for a period.
Let me know if changing ATF will oil pan helps..... |
