F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Question to those of you lowered on H&R Springs
Studio RSR
      05-25-2012, 08:56 PM   #1
brandon @ eas
brandon @ eas's Avatar
Drives: F30 335i
I know the drop on the H&R Sport Springs is fairly mild, so are any of you guys having your car re-aligned? If not, how does the camber look? Any pictures showing the camber of your lowered car with stock alignment specs?
Thanks!
      05-31-2012, 08:21 PM   #2
ƒ°
ƒ°'s Avatar
101
Drives: ✚
335i on H&R Sport Springs here. I'll let you know about the camber after I get it aligned next week some time.
I think it might be different for the 328i, as it isn't as low.
      06-03-2012, 02:00 PM   #3
ric124
ric124's Avatar
Jamaica
452
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
I have a 335i with H&R Sports and it seems as if H&R recommends getting an alignment for super sports but does not mention it for sports.
I got an alignment anyway
      06-05-2012, 12:30 AM   #4
1.fresh.f30.335
Drives: 2014 535xdrive M-Sport
Hey ric, do you think the stock offset is ok with the sport wheels, or does it need 5mm spacers in the rear... I know, its not performance oriented, but Im not going to track these wheels with run flats haha
'12 335i Sport Apline White w/black... Totaled
'14 535i xdrive M-Sport Carbon Black w/Mocha Nappa
      06-09-2012, 01:12 AM   #5
ric124
ric124's Avatar
Jamaica
452
2017 BMW M2  [0.00]
If it clears it would look hot but im not sure if it clears.
      06-10-2012, 03:26 PM   #6
ƒ°
ƒ°'s Avatar
101
Drives: ✚
I measured. You could probably put 15mm spacers on if you wanted. I still haven't decided if I'm gonna do it, but if I do, it'll be 15mm rears, 10mm for the front.
      06-17-2012, 01:17 AM   #7
pkimM3r
pkimM3r's Avatar
205
Drives: m3 saloon in granny mode.
How do springs affect the suspension when switching to sport comfort eco?
      06-17-2012, 03:57 PM   #8
ƒ°
ƒ°'s Avatar
101
Drives: ✚
The springs do not affect the different modes. It just lowers the car. Less travel room in the strut combined with stock dampers that are calibrated for the stock height will result in worse ride quality. Again, modes will not be affected.
      06-18-2012, 04:21 AM   #9
pkimM3r
pkimM3r's Avatar
205
yeah did some research on how all the electronic madness works with suspension. without adaptive m suspension does not change....when are coilovers coming out?!
f30post
