E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Squeal when starting from a dead stop
Reply
      06-05-2012, 06:20 PM   #1
wren57
Roll Tide
wren57's Avatar
591
Drives: 335i
Lately I've had a high pitch squeal from the front when I start rolling from a stop. I hear it up to about 8mph. I can only hear it with the windows down, but I don't want people outside hearing my car squeal. I recently changed my rotors/pads and used lots of anti-squeal on the pads, and it doesn't squeal at all when braking so I don't think that is the culprit. Any idea what it could be? Are there grease-able bushings in the front of the car?
      06-05-2012, 07:12 PM   #2
e92oholic
Drives: 2013 MINI JCW GP
Mine too but from the rear of the car. Its so embarrassing. I can't figure out why it does it either.
      06-05-2012, 07:13 PM   #3
dieselgg
Drives: 2009 E90 LCI 335i
It could be the brake sensor. A lot of people have reported this issue. Sensor wears prematurely and is touching your disc. I guess it all depends when you last changed it. Not sure if there is a new pn for the break sensor. Anyhow, this is just one possibility
      06-06-2012, 08:52 AM   #4
Surly73
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
I disagree that it's the sensor as my squealing is related to the p-brake not releasing fully when there's still some heat in the brakes (i.e. a short stop at a store).
There's a whole thread on it in Maintenance forum I think, no need to start another about the rear squeal.
I think this thread is about a different squeal if it's coming from the front.
      06-06-2012, 09:25 AM   #5
tanginaglaz
tanginaglaz's Avatar
Drives: 2007 e92 335i
Had the same issue a couple months ago. The car would squeal really loud from the rear at low speeds, but the squeal would go away when I applied the brakes. Took apart the rear brakes and put a thick layer of anti squeal film. The squeal went away after doing this. Here's the product I used:
      06-06-2012, 10:54 AM   #6
blingman
Drives: 3er
My front left area squealed every time I came to a slow stop. I figured they were the brake sensor that lot of people reported. A 30 minute job total to remove caliper and sensor and I just shaved it down enough before the warning light would come on(guesstimate). Squealing gone! The other sensor would be in the rear passenger side if its squealing with braking.
Reply
e90post
