What is this light that came up on the dash? (pic)
06-07-2012, 07:20 PM | #1 |
Rep 2,320
This is my mom's car. She said she was driving and heard and left a bang, almost like someone rear ended her and this light came on. I just went into the car to see it again but it's gone now. Anyone know what it means? It's not in the manual and I'm guessing something with the engine but not sure. Thanks
06-07-2012, 07:29 PM | #3 |
Rep 2,320
But it turned off. Also if we take it to BMW with the light not on they're gonna say that the engine check is "OK".
06-07-2012, 07:50 PM | #7 |
Rep 557
There is a code stored even though the light is not on at the moment. I assume you are under warranty? If not, it's gonna cost you... I think it's $110 just to scan at the local dealer around here.
06-07-2012, 08:04 PM | #8 | |
resident girl.
59
Rep 1,017
Drives: 2008 335i + 2014 X5
OP, your local AutoZone, OReilly etc will be able to scan the code for you for free. Get the code read and we can go from there. Or, if under warranty, just take it in to BMW. The code is there even if the light is not on anymore.
2008 E90 335i // Black Everything // photos COBB tuned / QTP e-cutouts / Helix FMIC / cp-e DCI / AWE BOVs / Catless / FBO + F15 X5 xDrive35i |
06-07-2012, 11:05 PM | #10 |
Rep 2,032
Drives: Red Flyer
The way to tell (since his username could be out of date or not apply to his mom's car) is to look on the tachometer. It has a MPG gauge beneath it, therefore it's a 328i. The 335i's have an temperature gauge.
06-08-2012, 05:18 AM | #12 | ||
Rep 18,808
In this particular case the OP can not take the car to AutoZone to get scanned. AutoZone and the like only have OBDII scan tools, which will only find an OBDII code that will only be present if the SES light is lit. |
06-08-2012, 05:31 AM | #13 |
Rep 1,727
Pretty much everything that happens to your car, the data will be stored in your key fob so whenever you bring it to the dealer, they will place it into the reader and it'll pull up mileage from the last time that specific key fob was inserted into the ignition to service and maintenance. Good luck!
Hiatus |
06-08-2012, 05:55 AM | #14 |
Came to the N55 Darkside
1115
Rep 12,740
06-08-2012, 07:40 AM | #15 |
Rep 857
Drives: 2008 Montego Blue 335i
Since its under warranty, just take it to BMW, it's free. Just let them do whatever.
06-08-2012, 08:39 AM | #16 |
Rep 1,555
That's not the check engine. Check engine lights up on the dash, this just says that the engine is running in limp mode for some reason and a lot of times when you turn the car off and on again that will disappear, until you recreate whatever happened to it last time that it went off.
06-08-2012, 10:42 AM | #17 |
Rep 5,627
06-08-2012, 10:45 AM | #18 | |
resident girl.
59
Rep 1,017
06-08-2012, 03:26 PM | #20 |
Rep 120
Got the same code when I was on a road trip, took it to the Canadian Tire (local mechanic) and they scaned it with the OBDII scanner which gave them a list of possible reasons (low ffuel pressure, needs oil change, needs oil filter change or mechanical problem) and rhey couldn't figure anything else out - said I go to the dealer. The dealer will just pop your key in the machine and figure it out, or run a diagnostic which for BMW's need to be run with the BMW scanner from my understanding.
Mine just needed a new oil filter because it got bent outta shape. Best of luck.
2006 BMW 330i
