Huge oil leak
06-10-2012, 08:02 PM | #1 |
Rep 3,469
So when I went to leave work on Friday, I walk up to my car and I see this huge streak of oil running out from under the car well past the drivers door. In a half hour or so that it took to call for tow truck and make arrangements, the oil had leaked at least another foot.
All the leaking had taken place in the span of about four hours. I can't post pictures as I'm on mobile, but it was a very huge leak that once the car was moved in total was probably about 6 feet long. Any ideas on what might have happened? In case you can't see my signature, I have an 07 335. The only good side to all this is I got an F30 loaner car, and it's been fun learning some of the new technology, and experiencing the N 20 engine. It's a brown modern line.
2016 Alpine White M3 (gone)
2019 Alfa Romeo Guilia (Totaled) 2020 Car-less 😁 (no more) 2020 M340 |
06-11-2012, 09:15 AM | #4 | |
Rep 3,469
06-11-2012, 10:18 AM | #5 |
Rep 12,680
Drives: like an asshole
Did you get an oil change recently, maybe the bolt wasn't tightened enough? You get a look-see underneath before it was towed.
06-11-2012, 10:27 PM | #10 |
Rep 3,469
Update: Oil pan seal is leaking. Replacement is ~$1600. I so can't wait to get rid of this car even though I love it so much. I am now at about $4600 in repairs the past 7 months. It's just not worth it anymore. Trying to find a CPO 335 sedan and there are none in my area right now, but lots of coupes though.
06-11-2012, 11:22 PM | #11 |
Rep 1,465
why does it cost $1600 to replace oil pan gasket? I've dropped oil pans on toyota camrys and civics, and they didn't take no more than an hour to drop, clean, and replace. $1600 is a robbery.
06-12-2012, 12:46 AM | #12 |
Rep 1,325
Most BMWs require you drop and/or remove the front subframe. The bill is all labor - well plus the 300% markup on the gasket and new set of aluminum pan bolts that you are supposed to replace. It's a $60 DIY project otherwise.
06-12-2012, 12:50 AM | #13 |
Rep 12,680
That's insane. How did it start leaking that bad out of no where.
06-16-2012, 09:59 AM | #15 |
Rep 1,274
Fraggy, did you have the option of getting extended warranty before the warranty expired?
2011 e90 KW V1, JB4, BMS Dp, BMS Intake, CP, Alpina Flash, ISO, E85
Coming soon to the garage: 2014 M3 Maybe M5 |
06-16-2012, 02:55 PM | #16 | |
Rep 701
Is that the dealer quote ? If you're in SD, Try Euroautospot in Miramar. They're an Indy BMW repair and it will probably cost less. |
06-17-2012, 08:24 PM | #17 | |
Rep 3,469
06-17-2012, 08:27 PM | #18 | ||
Rep 3,469
06-17-2012, 11:32 PM | #19 |
Rep 7,433
Out of curiosity, how old was your oil? Just looking at the color..
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
06-18-2012, 05:08 PM | #20 |
Rep 3,469
Not too old at all, a couple months.
06-18-2012, 06:23 PM | #21 |
Rep 349
I have a 2011 328i. Had small leak and thus took it to dealer. First they thought it was gasket and had to order (not in stock locally). When they dropped the pan to do gasket they found pan was defective and had to order that and there was only 1 in the US which I found strange.
When they told me it was a long job they talked about the front suspension issue. Fortunately, mine was under warranty. I really am convinced that I don't want to drive one of these cars with no warranty or maintenance plan. If it is $1,600 for a gasket replacing pan and gasket has to be at least $2,500 from a dealer. At least I got a free (only 5,000 miles on the car) oil change.
2011 328xi black on black. Nav, connect, apps, Sirius.
06-18-2012, 06:33 PM | #22 | |
Rep 380
sucks!
