M3 - Super Unleaded
06-12-2012, 01:40 AM | #1 |
Rep 252
M3 - Super Unleaded
Hi,
As the title really....do new e92 m3's have to be run on Super? Thanks
NOW SOLD - Counting down to the M3 - E92 May 07' 335i M-Sport - Sapphire Black - Manual - Black Leather Interior - Heated Seats - Bluetooth Handsfree - BMW Performance Black Grill - 19's - Saying No to the Diesel Revolution!
06-12-2012, 02:31 AM | #3 |
Rep 13,043
Drives: BMW M340I G20
Yes it's recommended you use 98 RON in them.
06-12-2012, 02:33 AM | #4 |
Rep 215
No it will run on 95 just fine.
I try and use super when available and it does feel slightly sharper, but it doesn't really mind 95 that much. |
06-12-2012, 02:49 AM | #6 |
Rep 13,043
I have filled mine up with 95 once, when I could get 98 and it idled rougher and spits and farts about a very low RPM. It doesn't make a lot of difference once up and running. I image the knock sensors just retard the timing back a little to compensate.
As per Jimpom really, if you need to save £4 per fill. You need to change your car for something else. Last edited by creepy coupe; 06-12-2012 at 03:10 AM.. |
06-12-2012, 04:02 AM | #8 |
Rep 8,972
They'll run just fine on 95 or less probably, but you need super to get to the best from such a high revving engine.
Smoothness aside, on a N/A engine it will suffer at all revs, but more so above 6krpm with 95 ron because the ECU can't maintain the kind of ignition advance really required to operate efficiently above that speed without detonation, so it has to use less ignition advance, thus the torque will tail more rapidly, reducing power output at all revs but more so higher up of course. This is even more so in a 335i, where evolve have dyno'd differences of 40bhp between 95ron and Vmax99 Vmax FTW! Last edited by doughboy; 06-12-2012 at 04:21 AM.. |
06-12-2012, 06:41 AM | #9 |
The Tarmac Terrorist
951
Rep 29,345
Drives: 997.2 GT3
Only ever run V-power 99 in mine!
997.2 GT3
06-12-2012, 07:27 AM | #11 |
Rep 13,043
I find V Power much less beneficial in the M over the 335i. As you might expect
06-12-2012, 07:31 AM | #12 |
Rep 617
I only have a lowly 335i and I still always run that on V-Power. Runs smoother, feels like it pulls harder and I get a slight increase in mpg which offsets the few pence per litre difference in price. If I changed to an M3 I wouldn't use anything less to be honest either.
Any high performance engine is susceptible to det when pushing on, yes modern ECU's can retard the timing to avoid problems but then you loose power and the possibilty of causing damage to the engine is still there. This is a car which will then no doubt be sold on as "one careful owner" Why would you spend thousands on a car like an M3 to then scrimp what amounts to a few quid a week on petrol? Also what else will the owner be scrimping on? Sorry but questions like this about premium high perfomance cars completely baffle me?? |
06-12-2012, 08:37 AM | #13 |
Rep 8,972
06-12-2012, 10:24 AM | #14 |
951
Rep 29,345
Drives: 997.2 GT3
My is flat on normal juice.
997.2 GT3
06-12-2012, 01:02 PM | #15 |
Rep 1,272
check the handbook and the fuel flap...it will run on 95 no bother at all but for "optimum" performance 98/99ron should be used.
V power (shell) and Momentum? iirc (Tesco) are the one's to use, BP Ultimate is marginaly better than normal unleaded with regards to horsepower figures and knock threshold.
Monte Carlo Blue M3 Comp |
06-12-2012, 01:18 PM | #16 |
951
Rep 29,345
Drives: 997.2 GT3
Total excellium.. What RON is that stuff?
997.2 GT3
06-12-2012, 02:49 PM | #17 | |
Rep 252
Sorry for baffling you...
06-13-2012, 01:04 PM | #19 |
Rep 1,272
Not according to BMW, as per the handbook mate
Will obviously be more beneficial on boosted engines, but still requiered for high performance (high compression) engines to get maximum output.
