Tire Pressure Monitoring System
06-13-2012, 09:49 PM | #1 |
Rep 185
OK, my car is 9 months old and the TPMS has failed, giving me a continuous tire pressure warning when the pressures in the tires are all OK. So, I will line up my car for its first trip back to the dealer for a warranty issue.
I have to say that even when working properly, that this system did not work nearly so well as the one on my 2008 Corvette, which gives me accurate tire pressures in each wheel at speed. And it does not seem to need all of the recalibration that the BMW system requires. So I will have my initial impression of BMW dealer service. Maybe I can get BMW to fix the rear doors that are reluctant to shut while they are at it. |
06-14-2012, 12:42 PM | #2 |
2020 Z4 M40i - 2022 M4C Convt
3131
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Mine is in the process of dying...be interested to hear how you make out.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
06-14-2012, 12:55 PM | #3 |
BimmerPost Supporting Vendor
2051
Rep 25,989
Very good possibility that the batteries in the sensors are out or low. Should be a simple fix if this is the case.
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
06-14-2012, 12:57 PM | #4 |
Rep 3,143
06-14-2012, 03:15 PM | #5 |
Rep 317
Don't E90s use ABS sensors to predict tire pressure changes? That was my understanding...
BMW 320 dA LCI, BMW PPK - 197HP, 2010, sapphire black, steptronic
06-14-2012, 04:16 PM | #6 |
3131
Rep 5,264
Just started to happen, have not done anything yet.
Kevin
06-14-2012, 06:51 PM | #8 | |
Member
Rep 72
06-14-2012, 07:16 PM | #9 |
Rep 241
How long is the batery life? Im having issues with a couple of tpms on my car? How easy is the fix for this issue? My tpms are from 2008
06-14-2012, 07:22 PM | #10 |
Rep 1,110
Canadian E90s generally have "FTM" (flat tire monitor) - and uses differential rolling rates of each wheel as measured by the ABS. Lower pressure and reduced effective circumference equates to higher revs and trips the low pressure alarm as either serious (yellow symbol) or critical (red symbol) pressure to one of the wheels.
Unless you have steel stems, it is highly unlikely you have the US-spec TPMS. Regards D.
2016 GLE 350d - White on Black
06-14-2012, 09:02 PM | #11 | |
Rep 185
Tire Pressure Monitor System
Today there was no TPMS alarm all day long. what's going on? |
06-14-2012, 10:32 PM | #12 |
3131
Rep 5,264
Similar issue - it randomly comes on then clears itself. Manual reset has no effect. Tire pressures all check normal with a few different gauges.
Shut the TPMS down with the JB4 setting 4/6. Will see what happens.
Kevin
