E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > streaming iphone music through car
Reply
      06-16-2012, 01:46 PM   #1
chris325
chris325's Avatar
Drives: 325i msport coupe
Chaps
Just got myself an iphone, never had one before and want to know the best way to stream music from it to the cars' speakers.
It has a jack in the armrest that I can connect it to, but that means a cable trailing out the armrest.
Any ideas/experience.
Costs - I'd like to keep it below £200, I'm not going to do a CIC retrofit or anything!
Car is a single humper '57 plate.
      06-16-2012, 02:09 PM   #2
Brian mc21
Brian mc21's Avatar
Drives: E91 320d M Sport
If you don't have hands free fit a parrot mki9200 phone kit. You can charge the phone and use the leads to play the music or you can play the music through it via blue tooth which is what your after.
E92 330D LCI
NSR 250 MC21, CBR 600RR 3
RVF400
      06-16-2012, 02:16 PM   #3
335d Rocco
335d Rocco's Avatar
England
114
Drives: G01 BMW X3 30d M Sport Plus
I've got Bluetooth in my e90, can I play music from my iPhone through the cars speakers??
      06-16-2012, 03:25 PM   #4
Brian mc21
Brian mc21's Avatar
I'm not sure mate. Never had Bluetooth. But I did have the above fitted to my last e90.
E92 330D LCI
RVF400
      06-17-2012, 03:29 AM   #5
BanziBarn
BanziBarn's Avatar
106
Drives: BMW 330D E90 LCI Msport
I've got a pad from firebox that sits on top of the ash tray. When I put my phone on it it sticks and doesn't budge.
Then, I have the cable connected in the arm rest which trails out by the side of the seat and is then tucked under the trim all the way down to the ash tray area.
It's not the neatest solution but looks OK.
I don't use it much though as I have USB.
In your situation I'd probably get a Bluetooth receiver connected to the 3.5mm jack , either battery powered or one that can be powered by the socket in the armrest and the play music over Bluetooth.
Black 330d E90 LCI M Sport Saloon Auto. Privacy Glass, Cream Leather, 6FL, I-Drive/Nav/Bluetooth, Alpine hifi upgrade.
http://www.e90post.com/forums/picture.php?albumid=2148&pictureid=44259
      06-17-2012, 03:58 AM   #6
Dr Dave
Zummerzet Zyder Drinker!
United Kingdom
112
Drives: '06 330D Le Mans Blue
Hmmmmm now thats interesting.....a 3.5mm BT reciever. That would work well for me too.
      06-17-2012, 05:33 AM   #7
Aaronboydefc
Drives: 335d
Cant u buy the snap in adapter?
      06-17-2012, 05:51 AM   #8
Squintstream
Squintstream's Avatar
United Kingdom
141
Drives: F32 435i M Sport
Snap in adapter only streams music on the newer sat nav systems and provided you have the media option, or whatever it's called
Most cradles only charge the iPhone and connect to the shark fin aerial for better reception.
      06-17-2012, 01:46 PM   #9
SIMPSD3005
Drives: E90 Performance Edition
You can try the belkin air cast auto. It connects to phone via Bluetooth and has an audio jack that goes into the aux. you can leave the receiver tucked away or have it out as you can use it as a bluetooth phone through the aux radio setting. Works with i-phone voice commands.
Make sure it's the air cast auto as there is another version which is non Bluetooth. Think it cost around £35.
      06-17-2012, 02:46 PM   #10
BanziBarn
BanziBarn's Avatar
106
Sounds like just the job!
Might get one of these for the house.
      06-17-2012, 03:21 PM   #11
-TARBY-
-TARBY-'s Avatar
England
11
Drives: 07 330d M Sport Saloon 6 Speed
I just bought this
http://www.amazon.co.uk/7dayshop-Blu...9964369&sr=8-2
It works in my mates car fine so have no reason to think why it wouldn't in my new purchase.
I'll let you know
Tarbs
2007(07) : e90 - 330d - M Sport - Saloon - 6 Speed
      06-18-2012, 07:05 AM   #12
jimpom23
Drives: 335i
You can get that but you won't be able to use the steering wheel controls
I don't have USB or iPhone adaptor but just burn data discs which will play in the CD player - I can get well over 100 songs and can split them into folders (different genres/playlists), all of which are displayed and selectable through iDrive - works seamlessly and costs no more than the price of a cd
      06-23-2012, 08:48 AM   #13
-TARBY-
-TARBY-'s Avatar
England
11
The device I mentioned above has arrived this morning and I am delighted with it. I have an iPhone and I can stream music and any sound output from my phone to the blue tooth gadget that's plugged into the aux slot in centre console. I switched to aux in the entertainment options on the idrive and hey presto. I can use the steering wheel volume buttons no problem. The BT connection to the phone also has a connection to the system so when a call comes in or you make one it cuts out the aux/BT/iPod connection automatically
So it does work and is a good option for systems that don't have the USB port.
I am v pleased as this was one function that I have been used to.
      06-23-2012, 09:40 AM   #14
Masterplan
Masterplan's Avatar
124
Drives: F87 M2 & G05 X5
I guess you pair this up to your iPhone via Bluetooth.....but what happens when a call comes through?
Does it automatically switch to the cars Bluetooth stem allowing the use of the steering wheel controls?
If it still stays paired to the cars BT, then that's a great solution to USB and auz wires trailing through the car!
      06-23-2012, 10:13 AM   #15
cyberlife
Drives: E90 320i
+1
This is what I use and it works great. I've got the receiver next to the ashtray so I have the thin wire coming down the inside of the armrest and tucked on the underside of the centre console popping out at the other end.
      06-23-2012, 10:55 AM   #16
-TARBY-
-TARBY-'s Avatar
England
11
I'll go test that - I tested everything else - including seeing that traffic rds announcements interrupt the iPhone>BT dongle>BMW Aux. I'll also go take some pics.
      06-23-2012, 11:10 AM   #17
Ligumo
Drives: E92 320d MSport
I'm a bit miffed with that, was just on the verge of getting a cradle for my 4S. I've got the professional radio in my 10 plate pre-LCI but no iDrive. Might get it anyway though. I saw on another (older) thread it was possible to burn MP3 CDs for use on the Pro system, which I was doing 10 years ago on the Pioneer HU I had in my Porsche 928!
      06-23-2012, 01:17 PM   #18
-TARBY-
-TARBY-'s Avatar
England
11
So I've tested it. It does work perfectly. I can make calls from the steering wheel and voice control. I can stream my music and other iPhone sounds via BT and the aux input. Then someone calls, the communication system kicks in, fades the aux sound out and then you've got control of the call via the steering wheel. You end the call and the aux input is back again.
The belkin one looks to do exactly the same plus it's powered. The one I have is very very small and is charged by a USB charger. Not sure how long it plays for.. Early days.
Tarby
Reply
e90post
