My E90 has Whoosh & Rear Inner Tyre Wear
06-27-2012, 08:15 AM | #1 |
Rep 137
Issue 1:
Because it's a nice day up North West I wound my window down but whilst driving and when accelerating (pressing gas pedal) I noticed a very loud whoooosh noise from, what seems like, below the undercarriage. Releasing the gas pedal and the noise goes away. Gently pressing it, the noise if not that evident don't think. The car is an E90 330d 55-plate. Is this the noise from the turbo? Or has my car developed an issue? Issue 2: Whilst monitoring my tyres conditions I noticed that the rear inner tyre and slightly on the inner wall, it has worn more than the outer. Is this a camber issue? Need help. p.s. since owning the car from Feb this year, I have nothing but issues, faults, and things wrong with it, makes me think whether the brand has gone a bit off in recent years!! |
06-27-2012, 08:24 AM | #2 |
Rep 533
Drives: F15 X5 40d M Sport
Issue 1: Sounds like the turbo spooling up.
Issue 2: I would say your camber set up is just wearing the inner edge |
06-27-2012, 08:38 AM | #3 |
Rep 70
Rear inner tyre wear is normal on e90 as it runs with a lot of neg camber.
Wooosh Sounds like turbos spooling up [you have two] If you hear a whistle or woow woow noise there cud be a problem. It's all about being the ultimate driving machine if you want a daily driver buy a mondeo 😃 |
06-27-2012, 09:41 AM | #4 | |
Rep 344
Drives: 911 C2S & '118D
06-27-2012, 03:57 PM | #6 |
The Tarmac Terrorist
951
Rep 29,345
Drives: 997.2 GT3
997.2 GT3
06-27-2012, 05:44 PM | #8 |
Bimmaaaa
23
Rep 635
Drives: E46 M3
06-27-2012, 08:55 PM | #9 |
Rep 3,016
Almost spot on ; the word 'twin' defines two items which are identical.
As I understand it, the 335d has dual turbos - smaller first stage (lower inertia/quicker spooling), larger second stage to sustain boost. |
06-28-2012, 04:36 AM | #10 |
Rep 137
Whoosh & Camber
Had my 4 wheel alignment done and the car is now much better. I have heard the E90 is common for negative camber on the rears hence the uneven tyre wear. Incidently I am not running RFT's so what tyre pressures are you putting in for non-run flats? I have staggered setup of Falken 452's.
With regards the whoosh from my turbos; I shouldn't be worried then as the turbo is (are?) doing what they're supposed to be doing? And, yes, this is my 5th BMW and I am loving it albeit carrying many faults and issues, but still puts an inner smile on my face. I bet my bottom dollar that most of you guys look back at your E90 once you've parked up!!! |
06-28-2012, 05:04 AM | #12 | |
Rep 15,858
BMW are now using using the expression 'TwinPower' turbo even for a single variable vane geometry turbo, confusing it even more. HighlandPete |
06-28-2012, 05:08 AM | #13 | |
Rep 668
It's clever and er... "carefully worded"! |
06-28-2012, 11:31 AM | #15 |
Rep 2,073
06-28-2012, 04:59 PM | #16 |
Rep 15,858
06-28-2012, 05:20 PM | #17 |
Rep 618
The 50d is also a 3-litre, albeit triple turbo set-up like the 40d.
Must admit, the efficiency figures on some of the new 40d's are very impressive for 300+ BHP machines. |
06-29-2012, 04:19 PM | #18 | |
Bimmaaaa
23
Rep 635
Drives: E46 M3
well i know the newer versions are quicker but dont know the mechanical changes..
InstaGram: Ajerthan |
06-29-2012, 06:40 PM | #19 |
Rep 668
The E90 LCI was fitted with the N57 engine which was the successor to the M57 engine found in the pre-LCI. In both guises, the 325d and 330d had identical turbo chargers.
The main difference were different injectors and mapping, and I suspect a few other things such as intakes etc. |
06-30-2012, 06:01 AM | #20 |
Rep 173
06-30-2012, 11:49 AM | #21 |
Rep 1,272
I do, all the time...although it's a 92
Monte Carlo Blue M3 Comp |
07-02-2012, 01:40 AM | #22 |
Rep 137
Whooosh Gone Louder
Whilst driving on the motorway this morning, I found the 'whoosh' + 'loud hissing' sound was louder than the other day.
So, I've had to drive back home and wait till 8am till I can call my BMW indy in Stockport. Anyone know where else in Stockport area I can get this fixed if I can't book it in with my local indy?? BTW, the engine management light also came on and had a dash board warning message "engine emissions low" or something like that. |
