Will 1 series wheels fit on a 3 series???????
06-28-2012, 02:08 AM | #1 |
Rep 573
I have a question I have been offered a set of 17" from a one series BMW , not a mark on them and got winter tyres on already with at least 5 mm tread... They were on a 135i so has 6 pot brakes and went on on problems... Will they fit on my car ?? offsets and pdc..... I don't know???.. Any help would be great
/// 1M V O sadly gone
/// M5 2014 LCI gone.../// M3 2015..gone..Z4 35i2015..gone ///M135i 2015 Lci...gone/// M3 2016 Lci Suzuka Grey .gone Z4 35is 2016 Now here |
06-28-2012, 02:54 AM | #2 |
Rep 831
Would need to know a bit more about the exact type of wheels, off set almost certainly will be different, doesnt mean they wouldnt fit though. Also 5mm on winters is not necessarily the same as 5mm on summers. Winters aren't really useable down to 1.6mm so don't assume you've got loads of miles left on them
F31 335d M Sport XD - Mineral Grey - Coral Red - 19" 442M - HK Audio - M Sport Plus Pack - Heated Seats Check out my E90stereo install guide - http://www.e90post.com/forums/showthread.php?t=540954 |
06-28-2012, 03:19 AM | #3 | |
Rep 6,110
Drives: Don't know yet!
Either of the two types will fit though,but you'll need a minimum of a 10mm spacer on all four wheels to make them look OK. What have you got -E90/1/2/3?
Never argue with an idiot on the internet. He will drag you down to his level and beat you with experience. |
06-28-2012, 05:04 AM | #4 |
Squadron Leader (Ret'd)
25
Rep 627
No, they won't fit. Having had 130i and sold it I tried my winters on the 330d. Not only was the offset wrong but the centre hole was a fractionally different size.
06-28-2012, 07:48 AM | #5 | |
Rep 6,110
The majority of Bmw's share the same PCD:5x120 & the same bore 72.5, it's certainly the case with the E82 & E9x. Offsets on the E82 range from ET35-45 Offsets on the E90/92 from ET34-39 (generally) The Spider spoke 142 17" wheel has an offset of ET47 on both the front 7J & the rear 7.5J,hence the need for a minimum of a 10mm spacer.
