F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Need help install painted reflectors on M-Sport
Extreme Powerhouse
      08-28-2012, 07:04 PM   #1
Serenitygal3
Formerly bmwluvr3 on e90post.com
Serenitygal3's Avatar
Drives: '13 335i M Sport
Hi guys,
I wanted to install my reflectors today that I got from ********** but once I unscrewed the panel, there were wires everywhere for the camera and sensor and I don't there is no way that I can put my hand through to pry off the orange reflectors....and I have small hands.
Do I have to unplug these wires? How do I do that? Is there any other ways to install these reflectors? Any help is appreciated! Thanks!!
AT with Shift Paddles - AW/Black Dakota Leather/Hexagon Aluminum with High Gloss Black Trim - Cold Weather Package - Premium Package - Driver Assistance Package - Driver Assistance Plus - Dynamic Handling Package - Technology Package - Parking Assistant - Harman Kardon Surround Sound System.
      08-29-2012, 12:55 PM   #2
Serenitygal3
Is there anyone that can give me some pointers? I would like to install them today but don't know how!!
      08-29-2012, 02:45 PM   #3
richb811
richb811's Avatar
465
Drives: 2020 G20 330i M Sport
Try this!
You may also need to remove the sensors to get to that reflector, clearances look pretty tight.
http://www.f30post.com/forums/showthread.php?t=730082
      08-29-2012, 03:30 PM   #4
Serenitygal3
I saw the DIY but I don't know how to remove the sensors. Is there a DIY for that?
      08-29-2012, 04:18 PM   #5
GTM_Challenge
GTM_Challenge's Avatar
Drives: E46 M3, E90 M3
You can just unclip the wire harness from the sensor and camera. the push tabs can be seen in your pics posted.
      09-08-2012, 03:59 PM   #6
agint
Drives: 2013 335i M Sport
just installed mine yesterday and had the same problem but i didn't need to unplug the harness. you can work around the sensors, it's just tough to get leverage on the original reflector. use a flat heat screw driver to pry the top of the reflector back and then you should be able to pull the rest back just with your hand. once the original is out, the sensors won't get in your way and the rest is cake. good luck!
f30post
