E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > loud rattle from engine when I start up
Reply
      11-12-2005, 02:12 PM   #1
Bobo
Drives: 320 D SE E90
Angry loud rattle from engine when I start up
320 d se
garage can't find anything wrong
any suggestions
      11-12-2005, 09:23 PM   #2
David328M-Sport
Australia
101
Drives: F30 M-Sport 328i Estoril Blue
garage or dealers service techs?
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      11-12-2005, 10:10 PM   #3
joony79
mOOnarchy
joony79's Avatar
21
Drives: 330i SG
2006 330I  [0.00]
I think it's because your car is BMW? maybe? I mean if it's your first BMW I had the same impression about the engine... but it's just because it's BMW... and there is nothing wrong with it... I guess you got your car not long ago because mine did the same thing at first and it was reduced after a while and now it's just like... I have to hear that sound of mine everyday.
      11-12-2005, 10:20 PM   #4
ON325i
ON325i's Avatar
Drives: e90 325i
2006 e90 325i  [0.00]
describe loud rattle, does the rpm stay at between 1k-2k. because if that is the issue, it does that everytime it starts my car either
e90 325i Jet Black / Sports Pkg / Auto
      11-15-2005, 05:46 AM   #5
Dante
Enthusiast
Dante's Avatar
Germany
468
Drives: F87 M2 / F31 330d
Does the rattle fade away after 2 seconds and only appear after having the car parked a few hours (e.g. overnight)?
Then its the self-adjustment of the valves. (sorry for bad description) It works hydraulic and has to fill up with oil after not running the engine for hours.
Thats normal, I experience the same on my 325ti, especially if its cold outside. Bit annoying though.
Hope that helped you
      10-06-2006, 05:45 AM   #6
kimchi
Drives: E90 325i Sport
Engine Rattle
Hmmm... seems this may be a common affliction. I have a 2 month old E90 (325i Sport) 3.0 gas six (US Spec) and I am experiencing a rattle from the engine. It started last week, and has only occurred 3 times... and ONLY when it is cool (less than 10C) and damp outside and only if it has not been running for a while. It will usually go away after letting it run for a few moments and/or driving a couple of kilometers. It rattles no matter the revs of the engine, but there is no discernible performance issue or anything other than its just noisy.
I took it to the shop and they said everything was OK with the car. They asked me to bring it in when I noticed it again, but as mentioned above it goes away after a few moments. So alas, I doubt I can get the mechanic to witness the problem unless I could convince them to keep the car overnight.
What I am gathering from this thread, is that I am not alone in this problem and that my initial suspicions are correct - the problem is related to hydraulics for the valves and lifters.
A long time ago I had an old 1980 AMC Eagle that had a straight 6 and it had exactly the same problem from the day the car was new. There wasn't anything wrong - it was just noisy valves and lifters. Maybe this is just an inherent issue with inline 6 cylinder engines.
I am interested in comments from others who might be experiencing this issue - hopefully it is just an anomoly. Thanks in advance.
Bryan "Kimchi"
Reply
e90post
