E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > My sunglasses tray thread
Reply
      11-15-2005, 08:54 AM   #1
Broken1
Addict
Broken1's Avatar
203
Drives: 2024 X5 40i M-Sport
So I decided to order the sunglasses tray today - they said I could collect it tomorrow afternoon (yaY) so I hope it's there when I go get it!
Anyways, got one or two questions:
1. Which screw driver do I need to install it? Where could I get it from (hardware shop? BMW only?) What does it look like? What size?
2. Seeing as I lose the cigarette lighter socket in the ashtray - could I put my cigarette lighter (the actual heating element) in my arm rest? Would it cause damage if I decide to use it one day?
It'll be quite exciting working on my car - it'll be the first propper screw and driver work I will be doing :-)
Thank to the DIY here, I am confident....lets hope it goes well!!
      11-15-2005, 09:02 AM   #2
afocoryw20
afocoryw20's Avatar
12
Drives: X3 + 325xi
2006 325XI  [0.00]
2005 X3  [0.00]
1990 Mercedes Benz ...  [0.00]
Look at this thread...
http://www.e90post.com/forums/showth...unglass+holder
      11-15-2005, 11:22 AM   #3
Broken1
Addict
Broken1's Avatar
203
Thanks, I saw that thread
It doesn't state what screw driver to use to undo the torx-20 screws, what it looks like or where I would get it from and it doesn't answer my other question about the cigarette lighter jobbie
Thanks for your help though/...
      11-15-2005, 11:26 AM   #4
Tierfreund
Tierfreund's Avatar
21
Drives: E90 330i
: You need a torx T-20 Screwdriver, what else? There really is no better way to say. Just go to a hardwarestore and tell them: I need a Torx screwdriver size twenty.
No, not THAT kind of tierfreund!
      11-15-2005, 11:28 AM   #5
Broken1
Addict
Broken1's Avatar
203
:blond moment: (thanks)
      11-15-2005, 11:29 AM   #6
Tierfreund
Tierfreund's Avatar
21
Drives: E90 330i
Happens to the best....
      11-15-2005, 12:23 PM   #7
06graphite
06graphite's Avatar
Drives: '07 328xi Coupe
i'm not sure I'd use the cigarette lighter (heater thingy) in the power point in the arm rest. From what I've seen on other cars (not BMWs admittedly) the power points are not rated for the current draw of the lighter.
Actual lighter ports usually use heavier wiring and the receptacle itself is rated for higher temperatures. But I'm not sure if BMW uses the same wiring and receptacles in the armrest or not.
      11-16-2005, 08:55 AM   #8
Broken1
Addict
Broken1's Avatar
203
Any one else know anything about this ^^^^^^^^^^^^^^^^^
So I installed the sunglasses tray today. It took less than 10 mins (thanks to the DIY). Pulling the trim out was harder then I expected, but I managed quite well! The sunglasses tray is surprisingly big. It's deeper, wider, and taller than the ashtray. I'm sure many non-smokers would like something like this. I had no use for the ashtray...but the handy storage from this tray will come in use!!! I might not even use it for sunglasses!!
      11-16-2005, 11:27 AM   #9
Broken1
Addict
Broken1's Avatar
203
Anyone?
      11-16-2005, 11:31 AM   #10
Orangeman5
Drives: 2006 330i j. black
How does the shift boot cover fit in to the center console trim cover? I'm not clear on how to remove the shift boot cover. Do you just pull it out? If so how do you get it back in?
330i MT/Jet Black/Black Leather/Walnut Burl Trim./PP/SP/PDC/CA/Sirius/Heated Seats
"Drive fast, take chances."
      11-16-2005, 12:07 PM   #11
Broken1
Addict
Broken1's Avatar
203
There are 4 black little plastic clips on the sides (seat sides) of it. I basically just pushed each side (at the same time - one side per hand) and it clipped up....
:P
Anyone on the ligher issue? E90Fleet? Anyone?
      11-16-2005, 02:44 PM   #12
MB330
MB330's Avatar
53
Drives: 330i
2018 BMW 330i  [0.00]
2006 E90 330i  [10.00]
Can I order sunglasses tray as a factory install options?
      11-16-2005, 03:10 PM   #13
thrill30
South Africa
16
Drives: 2010 E90 330i 6MT
Sounds like something I might want to do.... would you mind posting a picture of the sunglasses tray? I just wanna see how it looks when installed.
E90 330i 6MT|Space Grey|Red Brown|Alumin|Sunroof|Voice Control|Logic 7|Xenon|Prof-Navigation|Storage Pack|Luggage Pack|Extended Lights|Anti-dazzle Folding Mirrors|Climate Comf. w/screen|M-Sport Pack|Exclusive Pack|Innovations Pack|Alumin Pedals|CF Splitters|Delivered:19 March 2010
      11-16-2005, 03:41 PM   #14
3aficionado
3aficionado's Avatar
Italy
17
Drives: 02 M3/RRover Super
Interesting idea. I'm a little confused by the question and maybe others are too.
Do you mean you want to try to just plug the cig lighter into the Aux power outlet in hopes of using the cig lighter?
Or do you mean you want to replace the Aux power outlet next to the Aux In jack with the cig lighter socket so you can use the cig lighter?
Or do you mean you want to add the cig lighter socket to the armrest in addition to the aux power outlet thats already there next to the Aux In jack? If so, would you be drilling your own hole somewhere in the armrest for the cig lighter?
The only reason I could see for keeping the cig lighter socket is for the additional power outlet for more devices (option #3). Using the cig lighter in a car without an ash tray doesnt make much sense.
      11-17-2005, 01:11 AM   #15
Tierfreund
Tierfreund's Avatar
21
Drives: E90 330i
Not in the US.
      11-17-2005, 07:37 AM   #16
jigga
Drives: 2013 X6 50i
pics please?
      11-17-2005, 09:38 AM   #17
Broken1
Addict
Broken1's Avatar
203
I won't have time to post photo's until the weekend, work is really hektic... but here is a photo from the DIY thread mentioned above...
      11-17-2005, 10:02 AM   #18
E90Fleet
South Africa
1312
On the ligther thing
All the powerpoints run throuhg the same fuse, but the front socket is different
Its also listed as a lighter and the others are listed as power points
So maybe the lighet wont work in the other sockets ???
      11-17-2005, 02:05 PM   #19
thrill30
South Africa
16
Cool .... thanks. I like it.
Reply
e90post
