Throw out bearing going out at 70k?!??
10-20-2012, 01:55 PM | #1 | |
Team iTouge
121
Rep 2,101
Recently there's been a lot of chatter around my engine bay and inside of the cabin. After a long drive, the chatter comes back and my buddy told me it could be the throw out bearing. So I dip my clutch whenever I hear it and it goes away until I release again. Its very feint but still a concern. Is there anyone else that had this problem??? Please help!
10-21-2012, 10:52 AM | #2 |
Rep 282
A throw out bearing would make a grinding noise when you depress the clutch pedal. Not when it is released..... So basially your clutch is chattering a little bit, which means your flywheel and clutch when making contact makes some noise.
Your clutch is starting to go out. Not the throw out bearing. I wouldn't be overly concerned unless your clutch sticks to the flywheel after you release it to shift or when it is fully engaged your revs jump when you give it gas. That is a good indication if you need to change the clutch. These cars have a good amount of chatter at idle with the clutch engaged. |
10-21-2012, 11:25 AM | #3 |
Rep 12,570
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.07] |
Clutch chatter is normal on these cars. I've had it from day 1 and so have all my buddies.
10-21-2012, 04:24 PM | #4 | ||
Team iTouge
121
Rep 2,101
