E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Please Help Diagnose - 335i Service Light On.
Reply
      10-25-2012, 06:30 PM   #1
Josh1a1h
United Kingdom
170
Drives: AzuriteBlack 335i E92
Boffins Needed!
I have a 2007 335i e92
JB4 Map 5 - Shell V Power
BMS DCI
65,000 miles
Had Turbos warranty replaced 1 month ago.
I was on my way home on a relaxed drive. I wanted to pull softly to overtake a lorry whilst going up a small incline.
All of a sudden, Engine light came on. I did not even attempt to pull hard to see if i had loss of power. But the engine was immediately running rough. I crawled home for a mile or so under 2k rpm.
I tried to read the codes on my JB4 once i was home. But i am unsure if i read it correctly. I have a vid below of what i did. Please direct if that is right and help read the code.
There is also a short video of my car idling.
I am unsure what the issue may be.
I was just about to install my VRSF DPs, i can take the car to BMW if necessary, but i will pull the JB4 and DCI. Need as much info as possible so the stealers dont try to mess me around.
Engine Code -
Engine Rough Idle -
      10-25-2012, 08:19 PM   #2
Josh1a1h
United Kingdom
170
Sorry guys but need to bump desperately. I may be forced to crawl the car to the dealer or an Indy... But unsure what the code is or how to read it.
      10-25-2012, 08:31 PM   #3
Joe-
Drives: 07 E92 335i
I don't have a jb install so I honest don't know do you know what the code translates into?
      10-26-2012, 12:52 AM   #4
TheTal0n
TheTal0n's Avatar
51
Drives: 2006 330i
tuned but you dont have a scan tool?
plug/coil?
intake leak.
      10-26-2012, 02:00 AM   #5
Josh1a1h
United Kingdom
170
Was the way I was reading the codes correct in the video above?
      10-26-2012, 07:20 AM   #6
Josh1a1h
United Kingdom
170
Worked it out.
Miss fire in cylinder 4.
Going to have coil packs and all plugs replaced. Hopefully that should solve the problem.
      10-26-2012, 08:49 AM   #7
phillip@bmpdesign
Drives: 2008 BMW 335i
Or just the coil pack and plug in cylinder 4. Fairly rare for packs to go out, let alone all 6, if you replace with OEM then just the 1 should be fine. And this is a relatively general fix for a problem when you aren't sure what exactly caused it, so no sense spending unnecessarily.
Phillip Wilmeth
-=BMP Design=-
1-800-648-7278
Like us on facebook!
Reply
e90post
