Turbo stopped kicking in
10-31-2012, 10:38 PM | #1 |
Rep 73
Hi guy today I picked up my 07 335i e92 and it was rainy out with the DTS on. I gave it a push and turbo kicked right in, in second gear. The I slowed down right away, I heard a beep sound and check engine light came on. After that the car felt like it became weak, and did not feel the turbo kick in anymore, got a bit worried but the dealer said the computer shot off the turbo cause of the DTS noticed the sleeping. And after an hour or two after stopping and starting again the check engine light fully went off but I didn't push it anymore as I though I might have damaged somthjng with that one push.
Please share your thoughts. I did buy a third party Insurance from the dealer for 3 years which is a bumper to bumper coverage so I hope of anything it is covered. |
10-31-2012, 11:39 PM | #2 |
Rep 229
The tires slipping could result in a bit of overboost which would throw the car into limp mode (I think.) Would be helpful if you could pull the codes. Oh also a boost leak leads to limp mode too. Unless that's just with a tune..
2007 335i, Space Gray, Black/Alum, Sports, Prem, CA, Navi, iPod
11-01-2012, 07:45 AM | #3 |
Rep 73
The car when i test drove before buying it was working just fine, boost came in every single time i pushed on the gas, and I pushed it quite a few times when test driving it. This morning the turbo was working well on my way to work, i didnt kill it but i felt the boost come in a couple of times. After about an hour i forced it to go up a bit and it went back to no boost once more with the engine picture showing on the digital portion of the cluster.
When turning the car on i noticed that the is a light dedicated to check engine but this engine picture i see is on the digital portion. Any Thoughts? sorry i didn't get the car manual when i bought it. Any thoughts on where and how i can get my hands on a digital copy if any online of the car manual? |
11-01-2012, 08:24 AM | #4 | |
Rep 3,606
11-01-2012, 08:53 AM | #5 |
Rep 413
+1. You may have a completely unrelated problem to your turbo system.. You're engine may be losing power for a completely different reason making you feel like your turbo isn't "kicking in" .Wish I could be more help, but without some diagnostic codes, it could be a # of things. Best of luck
11-01-2012, 09:50 AM | #6 | |
Rep 1,201
By 'digital portion', you're referring to the LCD screen in the middle of the gauge cluster?
'08 E90 w/ just boltons
'09 Z4 sDrive35i w/ just boltons |
11-01-2012, 10:31 AM | #7 |
Rep 857
Drives: 2008 Montego Blue 335i
I think by digital he means can he find a PDF version of the manual, and yes, you can. Just get it off BMW im pretty sure...... You might have a boost leak in yoru vacuum lines. But like everyone else said, just go to a local indy shop, they can pull the codes and tell you in short time.
11-01-2012, 10:49 AM | #8 |
Rep 6,092
because vtec took over.
11-01-2012, 10:51 AM | #9 |
I'll get back to you
7569
Rep 2,132
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/ Countermeasure enthusiast. |
11-01-2012, 11:20 AM | #10 |
Rep 1,556
Vtec just kicked in, yo. You won't feel the tiny N54 turbos "kick in", boost builds progressively and smoothly. It is actually hard to even tell that these engines are turbocharged from behind the wheel. OP, have you considered the fact that maybe you don't know anything about cars?
11-01-2012, 11:22 AM | #11 |
Rep 1,201
I guess everyone missed that he got a CEL and decided to criticize him instead about mis-speaking.
11-01-2012, 12:15 PM | #13 | |
Rep 73
11-01-2012, 12:27 PM | #14 |
Rep 1,730
Ok guys, simmer down... OP, you'll need to either go to a shop or ind someone that can scan the codes your car is throwing. Based on those codes, you should be pointed in the right direction as to where the problem lies.
'11 Space Grey E92 335xi M-Sport (KWv1 Coils | Saddle Brown | Bamboo) (Returned)
'14 Mineral Grey F32 335i M-Sport (Dinan DHP | LED Lights | Coral Red | Hexagonal Aluminum) (Returned) '16 Mineral Grey F80 M3 ZCP |
11-01-2012, 12:41 PM | #15 |
Rep 1,024
This happened to me under hard driving conditions once and was found to be caused by a low quality oil filter that had fallen apart into three pieces and was impeding the flow of oil.
11-01-2012, 04:55 PM | #17 | |
Came to the N55 Darkside
1115
Rep 12,740
11-01-2012, 05:54 PM | #19 |
Newbee
27
Rep 139
Did you just purchased it from a dealership? If you did, take it back to them. You also mentioned 3rd party warranty. I would take it back and have them fix it.
Like others mention, the turbos don't kick in, the powerband is smooth from 1500-1800rpms to redline. Since max torque comes on early (1500-1800rpms) you may feel being pushed into the seat. Also, without any codes we can play the guessing game all day. Take it back and let them fix it, then come back and post what they found wrong and how they fixed it. This way we all learn what the cause was and the solution. Just my .02cts.
2016 BMW M4 Convertible(F83). 2007 Dodge Charger SRT8 "SuperBee" 2012 Dodge Charger SRT8 (Wife's Car) |
11-01-2012, 08:44 PM | #20 | |
Rep 73
Can the code be available of the check engine light is off? |
11-02-2012, 07:00 AM | #21 | ||
Rep 361
11-02-2012, 08:04 AM | #22 | |
Rep 276
You were pushing it in the rain. Sounds the the TCS just detected some wheel spin and cut engine power. You're probably not feeling the "kick" because TCS is limiting the power in low rpms and by the time power is restored you're already moving. Like others have said, these cars have litttle to no turbo lag so you won't be feeling a "kick".
'16 BMW M3
'16 BMW X5M '23 X3 M40i (On Order) '21 Civic Type R |
