Thinking of buying used 2007 335i coupe...thoughts please!!!
11-07-2012, 09:29 PM | #1 |
Rep 136
Features include premium package, sport package, cold weather package,and navigation. Basically fully loaded right? Only has 30,000 miles which is the main reason I'm thinking of buying. He's the original owner and asking $24,500. Kbb value is 25-26K seems like. Problem is warranty is expired.
Does it seem like good price...what should I offer? No warranty makes me nervous...car fax checks out. Thoughts appreciated. Thanks |
11-07-2012, 09:32 PM | #2 |
Rep 1,404
If buying this car or equivalent, then buy a car with or partial warranty. Then you won't have buyers regret.
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
11-07-2012, 09:33 PM | #3 |
Rep 136
11-07-2012, 10:20 PM | #4 |
Rep 136
any thoughts from you experts on fair price to offer? He says due for oil change, brake fluid change next month....spark plugs and brake pads in 15k miles. how much will that stuff cost and can it only be done at dealer?
11-07-2012, 10:28 PM | #5 |
Rep 1,843
has the HPFP ever been replaced? Seems like 07 and 08 had more problems with those... price seems a little high to me as I paid less than that for a '09 w/ all the same options granted with 70K miles but in pristine shape.
11-08-2012, 01:49 AM | #6 | |
Rep 419
I don't even know what I would say if someone called me about a car I was selling and asked me to buy them an extended warranty. On a serious note, I believe you can not buy the extended warranty through BMW once the original new car warranty has expired. Atleast that is what the Vegas dealership told me, other dealerships might be more than willing to take your $3000.
Performance |Dinan Stage 3 Software|Dinan IC|Dinan OC|UUC/Corsa Exhaust|Koni FSD Shocks and Struts|Eibach Spings|Hotchkis Anti Sway Bars|6MT|Style |Aero Lip|Aero Rear|M3 Spoiler|BMW Gloss Black Kidney Grills|BMW Aluminum Pedals|BMW LCI Tail Lights|HID Fog Lights|25%Tint|Advan AVS Model F7 19" Rims|Lux V3 AEs|Premium|Sport|Comfort Access|
11-08-2012, 06:51 AM | #7 | |
Rep 136
11-08-2012, 06:59 AM | #8 | |||
Rep 170
One thing I would watch for is a leaking mechatronic sleeve and/or tranmission oil pan. Very common, and if not covered under warranty is about a $700-1000 fix done at the dealer. Look under the car, if you see the trans oil pan has oil on it, make them get it fixed, knock $1000 off, or pass. it will show up as possibly very small drips (maybe not even enough to drip) in the area further back from the oil drain plug. You can see the trans oil pan even with the underbody sheathing on, there is a gap between the front and rear covers, this is the area you'll see if there are any leaks.
2007 E93 N54 |
11-08-2012, 07:00 AM | #9 |
Rep 96
If you want a warranty, or even a car less likely to need one,just buy a new car. My 2 cents.
2007 Space Gray/Coral Red 335i (Dinan 3) 6MT Coupe - JB4 / P3 Boost Gauge / Dinan Stage 3 Suspension / Dinan Intercooler / BMS Dual Cone Intake / Stett Charge Pipe / AR Design Catless Downpipes / Dinan Dual Mass Flywheel / ACT 6 Puck Ceramic Clutch / BC Forged HB04 Wheels with Michelin Pilot Super Sports / OEM Aero Lip / M3 Spoiler / Painted Reflectors
11-08-2012, 07:40 AM | #10 | |
Rep 136
Was there a recall on the fuel pump? If he has yearly maintenance at the dealer would they automatically fix it? |
11-08-2012, 07:46 AM | #12 |
Rep 6,991
Drives: 15 F80 M3, 22 G01 X3 30i
I'd get him to back down on the price some, and then contact an independent shop with a good reputation to quote you their price on doing the required maintenance. My 07 has 40K miles on it, still on the original brakes, although I'll likely have those replaced in the next few months. I still use the dealer for oil changes, and that runs me under $90 with BMW CCA discount. If the car hasn't been abused (doesn't sound like it has) and you treat it well, it should be a great car to enjoy for several years.
And yes, you can take it to the dealer (or a good Indy shop) and get it inspected, but prices will vary.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
11-08-2012, 08:06 AM | #13 |
Rep 3,732
Drives: BMW S1000XR
I dont think anyone mentioned this yet, but pay for a pre-paid inspection (PPI). About $150 at a local Indy familiar with BMWs. The seller should allow this, if not walk away. The shop can look into the oil pan leak. The price seems fair considering the mileage and yes, you can buy an extended warranty from a BMW dealer and cost is around $1800 to $3000 depending on the timeline, car status, and coverage. FYI...you can also handle some of the maintenance yourself, if you are not mechanically inclined there are many DIY's in this forum. A good way to learn and will save you $$$.
BMWCCA member |
11-08-2012, 08:15 AM | #14 | |
Rep 170
And yes, OP, a PPI is an excellent idea. Either a shop that knows BMWs well, or the dealer. HPFP has a recall, 100K miles and I forget how long, but it will still be covered. I'm not sure if they will just automatically replace it at the dealer, or if it has to fail before they'll replace it.
2007 E93 N54 |
11-08-2012, 08:29 AM | #15 |
Rep 3,732
Drives: BMW S1000XR
Depends on the dealer and what options (warranty) they have. I bought a 3rd party warranty from my dealer in the past. There was also a group buy on extended warranties from a dealer in the 1Addicts forum last year.
BMWCCA member |
11-08-2012, 08:36 AM | #16 | |
Rep 2,431
My speeding isn't the problem. It's the Slow Folks ahead of me that cause accidents!
11-08-2012, 08:49 AM | #17 |
Rep 136
Thanks I'll check Edmunds.
11-08-2012, 09:03 AM | #18 |
Rep 3,606
i agree. Thats what my 09 is KBB at. I wouldnt buy one of these things without warranty. In the last 4000kms they have replaced the radio, 3 injectors and plugs, steering hoses, hvac fan, steering pump, steering rack and just did 3 more injectors and plugs. I realize some of this is bad luck but these are all problems that have occurred with other BMW drivers.
11-08-2012, 01:05 PM | #19 | |
Rep 136
11-08-2012, 01:56 PM | #20 |
I have to return some video tapes
362
Rep 4,712
I don't know if i'd go with a 2007. that's the first model year and will likely have a lot of problems.
worth buying a warranty or saving up a little more for a newer model
13 Carbon Black e70 X5M - 13 Black Sapphire e92 335i - 10 Le Mans Blue e92 335i - 09 Monaco Blue e92 328i xdrive - 07 Sparkling Graphite e92 328xi
11-08-2012, 02:04 PM | #21 | |
Rep 2,189
good luck ppp
Olds Starfire > Chevy Malibu > Isuzu I-mark RS & Honda Magna 500 > Grand Am GT & YSR50 > Nissan Maxima & Ninja 750 > X-Wife > Hyundai Excel > Honda Prelude > Honda Accord > Honda Prelude & Ninja 250> Infiniti G35 > E90 335i > Hyundai Genesis Rspec, Hyunadai Sonata > Kia Sorento > Honda CRV-EX |
11-08-2012, 02:32 PM | #22 | |
Rep 794
Drives: 2021 M2C, 97 M3
Remember your turbo wastegates are covered 84mo/82K miles, which sort of covers turbos, but not completely.
Performance Center Delivery, June 21, 2013: 2013 E92 335is | Le Mans Blue | Gray Leather with Black | 6MT | 19" Style 313's | Michelin Pilot Super Sports | BMW Carbon Fiber Rear Spoiler | |
