Brief burnt oil smell this morning.
11-08-2012, 08:13 AM | #1 |
Rep 513
Drives: 2006 325i (SOLD)
Seems my issues will never end This morning I was parked at a slight incline. I turned the engine off and ran inside for less than a minute. I came back out and started the car and got a waft of burnt oil smell from the vents. It dissipated in less than a block and never came back after that.
Now if you have been following my other threads I recently had the water pump replaced after it failed on the way into work. Could my little incident be related? Could it just be the valve cover gasket at 80k? All input is appreciated.
Regards,
SnyperX |
11-08-2012, 08:27 AM | #2 |
Rep 1,834
Drives: '05 E90 330i Manual
If your valve cover gasket is not leaking, next thing to check is the filter housing gasket - coincidentally right above the water pump...
11-08-2012, 08:40 AM | #3 |
Rep 513
Well I can tell you its not the oil filter housing gasket. I replaced that last year:-) As for the valve cover gasket, I do see some weeping on the passenger side of the engine by what looks to be some kind of electrical plug/cable (valvetronic motor harness maybe). I am going to have to remove the upper engine bay cover to see further back. After I got home and parked the car, I turned the engine off and popped the hood. I did not smell any burning oil. It would seem that being on the incline caused the issue?
Regards,
SnyperX |
11-08-2012, 08:44 AM | #4 |
Rep 2,217
i had this same [similar] after i changed my water pump! Make ABSOLUTELY sure the radiator drain plug is fastened tightly! These were warning signs that my plug was inching its way out and leading up to the whole thing falling out and my coolant dumping out into the middle of the road; leaving me stranded and looking like an asshole.
Also, if you spilled coolant onto your engine at all, it could be the liquid burning when it touches the engine block. |
11-08-2012, 08:45 AM | #5 | |
Rep 513
Regards,
SnyperX |
11-08-2012, 08:49 AM | #6 | |
Rep 1,834
What about the PCV? |
11-08-2012, 08:55 AM | #7 |
Rep 513
Well I also changed my spark plugs here a month or two ago and the old ones looked almost new with the plug holes looking spotless. I have not checked my PCV.
Should I be looking at #1?
Regards,
SnyperX Last edited by Snyperx; 11-08-2012 at 09:02 AM.. |
11-08-2012, 09:01 AM | #8 |
Rep 1,834
And no obvious signs of oil dripping on the garage floor etc? Also, out of interest, what is your car's oil consumption like, now and say before this burnt oil smell?
11-08-2012, 09:03 AM | #9 |
Rep 513
No oil dripping from what I can tell, but I have not had the spash shields off yet. This just happened this morning. I have never had to add oil between the 5-8k interval I go by. Please keep in mind that the car had 64k on it when I bought it a little over a year ago and now has 80k.
Regards,
SnyperX |
11-08-2012, 09:27 AM | #10 | |
Rep 1,834
11-08-2012, 09:38 AM | #11 |
Rep 513
Yes, 80k miles.
Regards,
SnyperX |
11-08-2012, 09:51 AM | #12 |
Rep 2,494
I had a similar experience recently after changing the oil. It turns out that I spilled some oil and it ran under the engine cover. This allowed the oil to pool in some areas on the top of the engine block. I took a sharp turn the next day and suddenly had smoke pouring out of my hood. I nervously pulled in to a parking lot and tried to figure out what was going on.
Turns out, when I took that turn, some of the pooled oil spilled out of the various crevices it was in and was being burned off as it dripped onto the headers. Pop your engine cover off and see if there's any oil sitting under there.
11-08-2012, 12:27 PM | #13 |
Rep 1,834
Worth checking this out! Often the simplest of things can cause an issue like this!
11-09-2012, 11:05 AM | #14 |
Rep 2,217
I cleaned out all the oil in the little crevaces around the spark plug housings... seems i had a lot of spilled oil down there and i didn't know it... i ended up using a clear brake-bleeding tube (or a clear straw works just as well) and stuffed a bit of a paper towel in the end of it (about 1/2") in order to "suck" it out... made things a lot easier and quicker instead of trying to cram a rag or whatever down there.
I still get the burnt smell in the morning, but i think eventually it will go away after the last of the oil residue gets burnt away. I cleaned all around the head gasket and no leaks (after running the car around town for 30 minutes) so that's a good sign. I ordered a new cabin filter too as mine is all blacked from when my car overheated and sprayed coolant everywhere. |
11-09-2012, 02:25 PM | #15 | |
Rep 1,834
11-15-2012, 12:16 PM | #16 |
Rep 513
So has anyone done this themselves? I keep reading that the VCG on the N52 can be difficult to change. I really need to be able to do this myself since I do not have the funds for another shop repair (just spend $1200 on the water pump and stat last month).
Regards,
SnyperX |
12-03-2012, 12:18 PM | #18 |
Rep 513
So I still haven't had a chance to get under the hood and have a good look around. I have gotten the burnt oil smell a couple more times since, but have been less faint then the first time it happened.
Regards,
SnyperX |
12-03-2012, 12:38 PM | #20 |
Rep 513
I did open the hood...LOL. The only thing I saw was oil that had weeped around a electrical connector on the passenger side below the valve cover.
Regards,
SnyperX |
12-03-2012, 12:53 PM | #21 |
Rep 3,904
Drives: 330i, 135i
Wash your engine and start from there....
12-03-2012, 12:54 PM | #22 |
Rep 513
Every time I hear wash the engine I shutter. LOL. Last time I washed a car engine it didn't turn out to well. Haven't tried it since.
Regards,
SnyperX |
