vibration when braking?
11-12-2012, 02:23 AM | #1 |
Rep 1,285
hi guys, i rarely give my 328i some throttle and today i did, and when i was braking a BIT more than usual my pedal vibrated 2 different times and after the second my car is kind of limping? when switching gears (AT). ? i tried resetting the "maps" that come factory with the gas pedal thing of holding for 25 secs while engine is off and not much of a difference..and i have done the reset before and worked like a charm but never had the vibration when braking harder than what i did today
No warranty, and is it something that will go away? something i should be worried about? |
11-12-2012, 04:56 AM | #2 |
Gateropode
329
Rep 2,848
Sure its not ABS kicking in ? If you feel like pulses in the pedal, its normal ABS operating. You should not drive that fast if you don't know that
If you have steering wheel vibrations, it can come from over torqued lug bolts, a bent rim, or suspension problems (then go get an alignment at BMW, they will tell you about it). |
11-12-2012, 09:36 AM | #3 | |
Rep 1,783
Koni special active red, eibach pro-kit springs, Remus exhaust, stage 3 intake manifold,Stage 2 AA tune, BMW Short shift kit. Silicon intake pipe. M3 control arms front, M3 rear. ECS trailing arm with whiteline bushings. Purple powerflex subframe bushings. Yellow power flex upper shock mounts. Single mass flywheel OE weight.
11-12-2012, 10:50 AM | #4 |
Rep 5,627
11-12-2012, 11:54 AM | #5 |
Rep 1,783
Can it be overtightend by hand? And if so will it go back if I tighten it to spec? I get a slight vibration or thump starting around 80. Its barely noticeable so I usually forget when driving long distances. Maybe it's road irregularities? I don't really feel it in the steering so maybe its from the back or maybe its just the sound from the tires?....now im confusing myself lol
11-12-2012, 01:12 PM | #6 |
Rep 1,285
i was going about 50-60 and braked hard and only my brake pedal vibrates? i changed my abs pump..hasn't been programed to the car but changed it so i doubt it is that? if the suspension is a possibility it could be that as my car sounds more sensitive when i hit little bumps on the street
11-12-2012, 03:34 PM | #7 | ||
Gateropode
329
Rep 2,848
Could also be a bearing, but its less probable and you'll know conclusively when it will make a strong woo-woo noise. Quote:
I strongly advice that you get used to the maximum brake capacity of your car in a controlled environment, accounting for a variety of weather, and train yourself at proper braking technique before trying to drive hard on open roads. Now, if you are an experienced driver, and you think that your braking shouldn't have triggered ABS, there are a variety of suspension condition that can make handling so bad that ABS kick in very early. If you think so, have your suspension system (tires, shocks, springs etc) inspected. Also remember that summer tires have little grip in cold weather, that can lead to surprisingly bad handling. |
11-12-2012, 03:56 PM | #8 | |
Rep 1,783
11-12-2012, 04:06 PM | #9 |
Life is better with burnouts
99
Rep 611
Don't forget about warped rotors
11-12-2012, 04:30 PM | #10 |
Rep 1,157
If the vibrations are only present during braking, and it suddenly manifested itself during one or two brisk stops, then I would look into disc glazing. From the sounds of it, your car had been gently driven, and when brakes dont get hot enough they tend to accumulate brake residues.
Perhaps a few hard stops got your brakes hot enough to begin releasing some of the residue, but left some uneven deposits. I would personally go find a deserted wide open road and complete a brake bed in procedure. Google or search the site. It is not a difficult process, but will require good driver judgement because higher speeds and hard accel/braking will be involved. But then, I could be something completely different. it can be pretty hard to troubleshoot over the Internet! |
11-12-2012, 05:44 PM | #11 | |
Rep 5,627
But if it is simply a vibration at 60~80 mph, then wheel balancing is a likely culprit. Tom |
11-12-2012, 06:14 PM | #12 | |
Rep 1,285
11-12-2012, 07:48 PM | #14 |
BimmerPost Supporting Vendor
2051
Rep 25,989
Sounds like warped rotors or rotors that are about to warp.
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
11-12-2012, 07:51 PM | #15 |
Rep 1,849
My rear rotors warped at around 25000 miles. It was noticeable as a vibration felt primarily in the steering wheel when braking from about 50mph or faster, especially down hills. Toward the time my appointment with dealership was coming up, the entire car would sometimes feel like it was shuddering. Replaced for free under warranty.
I found it rather odd the rears would warp before the fronts.
2011 E90 / Premium Package / Stage 2 PPK / Performance Suspension
11-12-2012, 08:09 PM | #16 |
Gateropode
329
Rep 2,848
Could also be that, or the milder sibling of uneven pad deposit. But my experience is that warped/glazed rotors provoke steering shudder rather than pedal feedback. Try Avocet advice anyway, it cost nothing.
11-12-2012, 09:18 PM | #17 |
Rep 1,285
Probably my rear rotors? will look into that as i last did the front a couple months ago rears should be due as well! thanks again guys all of you!
11-12-2012, 09:19 PM | #18 |
Rep 2,335
11-13-2012, 01:38 AM | #19 |
Rep 2,973
Control arms or on an e90 the pieces that substitute for control arms could be worn.
The bushings wear and that allows the wheels to shift rearward under braking load. e30, e36 AND e46 cars have this issues. I'd look to worn suspension components. |
11-13-2012, 09:10 AM | #20 |
Rep 6
Appears to be your rotors are warped. The brake rotors are bad and either need modified or changed, when you do this you need to also put on new brake pads.
Read about 4x4 vehicles breaking system
11-13-2012, 10:38 AM | #21 |
Rep 3,606
11-13-2012, 01:07 PM | #22 |
Rep 5,035
Surprised no one else mentioned suspension components. It could potentially be control arm or steering bushings. When those things are worn you will get some feedback in the steering wheel.
