Timing belt
11-14-2012, 10:09 AM | #2 |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
I beleve it's a timing chain. Have not seen a post where someone changed as a maintenance item.
11-14-2012, 11:26 AM | #3 |
Where'd my VTEC go?
481
Rep 6,067
It's a chain. Doesn't need replacing.
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
06-05-2013, 11:24 AM | #6 |
Push the skinny pedal granny this is a DE!
Rep 85
The only thing I know of on the chain is the guide need to be changed to keep proper tension on the chain (loose chain not good)
If you do decide to change your chain you will need some special tools to hold the cams in place. As well if you do that you might as well rebuild the VANOS heads when you have all of that apart |
06-05-2013, 11:53 AM | #7 |
Rep 1,087
Drives: 2006 BMW 325i
As some have stated...
It's a chain not a belt. Things that will eventually need replaced. #7 chain tensioner #2 chain guide rail #3 slide rail #1 Chain #4 & 5 #12 #6 Honestly with this motor I would safely say that they should be fine until 150k miles or more. You could always call BMW and ask when they recommend maintenance.
06-06-2013, 10:17 AM | #8 |
Rep 790
i wouldnt worry about it til 160-170k. unless you track you car often, daily driving wont create much wear if any.
2010 335i M sport
2008 328i 2006 325i 1995 Z28 6spd - 377rwhp rip |
06-07-2013, 03:35 PM | #9 |
EL JIMMY NEURON
44
Rep 1,180
Just make sure the chain guide is alright. Mine broke off and the rattle its makes sounds similar to the infamous ticking of the lifters. I didn't replace it and went a few months thinking it was the lifters and...it blew a hole in the oil pump and caused my vacuum pump to fail therefore causing loss of power to the brake booster and I had no brakes. Luckily I didn't have an accident as this all happened one night a few miles from home. I ended up replacing my engine.
2007 Jet Black E90 328i
Thread: http://www.e90post.com/forums/showthread.php?t=825249 Instagram: manutd_as |
06-07-2013, 04:20 PM | #10 |
Rep 1,256
Drives: '08 M3, '09 328xi Sport Wagon
06-07-2013, 08:23 PM | #11 |
Rep 1,951
In theory, the chain is rated to last "the life of the engine," which obviously doesn't mean a whole lot other than, with HIGH likelihood, the you'll dump the car before such a time as it needs replacing.
06-07-2013, 08:27 PM | #12 |
Rep 454
And what do you offer in response? Nonconstructive criticism?
335xi: JB4 G5 | KW V1s | muffler delete | BMS DCI | VRSF 7" FMIC | VMR v703 18x8 | and your mom |
06-08-2013, 06:11 AM | #13 |
Rep 1,556
Most chain guide systems are good for 150k+ with no issues. There are many, many early N52s with well over 100,000k with no trend of this being an issue. Plus, the vast majority of the time you will have some rattling for an extended period of time that gives you plenty of fair warning before it lets go. My guess is that the electronics in the e90s will crap out long before the timing chains.
06-08-2013, 07:17 AM | #14 |
Rep 18,803
LOL.
Man, you guys worry waaaay to much. It's a timing chain and is designed to last the life of the engine; just the same as the oil pump, bearings, pistons, rings, and all the other internal engine parts. If it had a replacement interval, then BMW would design the engine to easily replace it (e.g. a timing belt). Yes, it cold fail due to improper assembly, or a manufacturing defect in one of the parts in the system, but it is DESIGNED to last the life of the engine. The design-life of the engine is well past 150,000 miles. |
06-08-2013, 02:49 PM | #15 | ||
Rep 1,598
Read manutdas11 post, does that sounds like it lasted the life of the engine? you must be from the stealership because that's what they all say Quote:
06-08-2013, 03:10 PM | #16 |
Rep 1,951
I'm curious to hear more, but that's an unbelievably atypical situation and I'm curious as to how a missing guard leads to a hole in the oil pump. There are lots of missing details.
06-08-2013, 05:04 PM | #17 | |
EL JIMMY NEURON
44
Rep 1,180
06-09-2013, 07:02 AM | #18 | |
Rep 18,803
"Yes, it cold fail due to improper assembly, or a manufacturing defect in one of the parts in the system, but it is DESIGNED to last the life of the engine. The design-life of the engine is well past 150,000 miles." So manutdas11 had an engine failure (sorry to hear that) due to a broken timing chain guide, which caused by either of the two scenarios I stated, it doesn't mean the timing chain and related components are a maintenance item with a specific replacement interval, such as spark plugs. Read the Post, dude. |
06-09-2013, 07:05 AM | #19 | |
Rep 18,803
06-09-2013, 05:36 PM | #20 | ||
EL JIMMY NEURON
44
Rep 1,180
