E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Strange concept
Reply
      11-17-2005, 05:45 PM   #1
northcountry
Drives: 06 330i
Strange concept
I was just thinking . . with the synthetic oil change interval and the 140 treadwear Potenzas, there's a good chance I will be changing oil and tires at the same time. (ok, actually I changed my oil at 7,800 miles) but you get the idea.
      11-17-2005, 06:09 PM   #2
selm
Fight On!
selm's Avatar
Drives: 2006 325i
I've been meaning to ask, was does 140 treadwear actually mean?
      11-17-2005, 06:43 PM   #3
LEDZEP
LEDZEP's Avatar
419
Drives: 2009 E70 & 2011 F25
^ Treadwear numbers are really only accurate within the same brand, but a tire with at 300 rating would essentially last twice as long as a 140 before needing replacement for tread wear. You should check out the tire section or go to tire rack for more good info on that.
I think it is bad luck to be superstitious
      11-17-2005, 07:18 PM   #4
shuzmaker
shuzmaker's Avatar
Drives: e90 325iAS
2006 325i  [0.00]
treadwear rating at 140 should last you around 20K miles under normal driving conditions... ie: driving like an elderly woman.
. :: 325i :: JB :: ZSP :: Step :: BLK Dakota :: Hot Seats :: Tints :: Pilot A/S :: .
      11-17-2005, 08:17 PM   #5
ward
Drives: F
140 means different things to different manufacturers
you could easily burn through them in less than 12000 miles if you drive aggressively
      11-17-2005, 08:44 PM   #6
longtran
longtran's Avatar
1439
Drives: E90 M3
2006 325i  [0.00]
140=14000 miles.
      11-18-2005, 06:41 AM   #7
06graphite
06graphite's Avatar
Drives: '07 328xi Coupe
Originally Posted by longtran
140=14000 miles.
is that official or just an estimate?
      11-18-2005, 09:15 AM   #8
ben1364
Drives: E90 330iA
Neither. It is comparison between the tire in question and the benchmark tire from the same manufacturer under the same load, inflation pressure, same vehicle, same roadway, same temperature, etc., etc.
      11-18-2005, 09:35 AM   #9
Sho
Sho's Avatar
35
Drives: E90 325i 6-speed
325i sport pkg has 180 treadware.
      11-18-2005, 10:09 AM   #10
06graphite
06graphite's Avatar
thanks for the clarification!
      11-18-2005, 10:40 AM   #11
shuzmaker
shuzmaker's Avatar
Drives: e90 325iAS
2006 325i  [0.00]
      11-18-2005, 10:49 AM   #12
jmcphillips1
jmcphillips1's Avatar
60
Drives: 2012 128 Coupe
I am amazed at the reasoning for not following what BMW tells you to do concerning the oil. When the car needs new oil it will tell you, until then don't waste your time or money. Your car will be just fine. I have had 3 bimmers and have always followed the normal procedure and I have never had one single problem.
      11-18-2005, 11:01 AM   #13
scottz5
Drives: 13 F10 535xi & 11.75 E93 M3
I use them till they are bald, lol I like bald things!
13 F10 535xi JB/B working on it
11.75 E93 M3 MR/Black Stock (wifey)
11 F10 535i AW/CB Mods Gone
Reply
e90post
