Never noticed this: adjusting speed with CC
11-18-2005, 08:04 AM | #1 |
Rep 260
Perhpas this is in the manual, I just never noticed it. I was playing around with the cruise control (I don't get too much chance to try it living the the Bay area), and after it was set I was pulling and pushing on the stalk to adjust the speed. I saw the display increment 1mph for each pull/push. One time however I pulled harder and it adjusted 5mph. Pretty cool, works on pull and push.
BTW, I'm not sure what I did but I had braked and dropped my speed about 10mph. Thinking the CC was off, I pulled/pushed/clicked something by accident and I must have enabled the "resume" feature. The car took off like a bat out of hell and scared the sh!t out of me. Man, this car is quick!
Now I don't mind the commute 330i Sparkling Graphite | Terra | Walnut | Steptronic | Sport | Premium | Navigation | Comfort Access | Cold Weather Pkg |
11-18-2005, 08:07 AM | #2 |
Rep 2,168
I love this feature because it makes it easy to sit on a correct speed without having to fiddle with getting exactly on that speed when you engage the cruise.
What I do is go right up to the speed at which you get booked (an even 10km/h above the posted limit here) then do two little clicks to be 2 km/h below that speed, then I am all set...
'05 E90 325i | '06 E90 325i | '08 E90 325i LCI | '13 F30 328i M-Sport | '14 F10 535d M-Sport
Current: '19 G01 X3 M40i |
11-18-2005, 09:01 AM | #3 |
Rep 940
JamieA wrote in part, "...then do two little clicks to be 2 km/h below that speed, then I am all set..."
__________________________________________________ __This reminds me that all my past BMW cars (U S spec) equipped with CC have moved in 1 kilometer increments in response to a tap of the stalk. The E-90 moves in 1 mph increments. From Jamie's post it appears that current 3-Series cruise control programing is market specific. Interesting if correct... |
11-18-2005, 09:02 AM | #4 |
My Car is a HYBRID! It burns gas and rubber.
Rep 75
Another cool feature of the cruise that I just recently found out. if you keep the cruise control on while you go around a sharp corner the car will slow down in ratio to how steep the corner is. Then when you resume going straight it returns to the preset cruise speed.
330i/Monaco Blue/Beige lth/SP/PP/Nav/Heated Seats/Sat Prep
11-18-2005, 09:26 AM | #5 | |
Rep 2,168
11-18-2005, 09:33 AM | #6 | |
Rep 525
Incredible.
11-18-2005, 09:36 AM | #7 |
Rep 7,308
Drives: see above.
Thats true, it definately happens
11-18-2005, 09:36 AM | #8 |
Rep 2,168
This could be the DSC in action perhaps... I am going to give it a go now.
11-18-2005, 09:37 AM | #9 |
Rep 75
I am not kidding. It happened to me the other night. Was cruising on the highway @ 65 hit the offramp and as I went around the off ramp the car slowed down on its own with the cruise still on. The sharper the radius on the curve caused the car to slow down more. When I returned to straight speed picked back up. I was totally shocked!!
11-18-2005, 09:42 AM | #10 |
Captain Caveman
150
Rep 1,715
Do you love the lights that zooms around up to your speed or what? When I first saw this I literally said, "Oooo! Oooo! Oooo!".
11-18-2005, 09:48 AM | #12 | |
Rep 7,308
Drives: see above.
11-18-2005, 10:51 AM | #13 | |
Rep 940
Thanks Jamie. I think that confirms that the programing in AU is in kilometers and my experience with the U S spec. E-90 is that it is in mph. Previous U S spec BMWs were in kilometers. |
11-18-2005, 11:42 AM | #15 | |
Rep 874
2018 F87 M2 | LBB | Executive | Moon Roof | Apple CarPlay [2018 F22 M240 (sold) ; 2015 F22 M235i (sold); 2006 E90 330i (sold); 1983 E30 Coupe 320i (sold)]
11-18-2005, 11:44 AM | #16 |
Rep 2,909
In I-drive, you can switch between KPH and MPH (also mpg and l/km, etc). I am not sure if this will change how the C/C operates. I'll mess with it later.
11-18-2005, 11:48 AM | #17 | |
Rep 127
11-18-2005, 12:39 PM | #18 | |
Rep 35
2006 325i USA spec- Jet Black/Black Leather/Burl, Steptronic, ZPP, Xenons, Sat Prep
