F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > HID color temp to match Ae's?
ARMA SPEED
      12-10-2012, 11:45 PM   #1
Chris@codemybimmer
BimmerPost Supporting Vendor
Chris@codemybimmer's Avatar
Drives: AW F30 328i Xdrive
Anyone know a roughly close color temp for HID's to match the AE's?
i want to get them installed in my fogs so i can run them Ae's+Fogs but i want them to match.
thanks
      12-11-2012, 03:53 AM   #2
MarkW83
United Kingdom
26
Drives: F30 330d M Sport
I know the colour temp for the Xenons is 4300k, so I'd assume the angel eyes to be the same/similar, as they're designed to match?
F30 330d M Sport Mineral Grey / Coral Red
Pro Nav/Visibility Pack/Comfort Pack/Harman Kardon/Head-Up Display/Electric Seats/Comfort Access/Adaptive Suspension...
      12-22-2012, 02:13 PM   #3
utenigma
Drives: 2013 F30 335i 8SA M-Adaptive
I put 7500k in and I think they match well
Originally Posted by utenigma View Post
Took delivery of my 335i yesterday, and <24 hours later it's been coded and now some of the bulbs have been changed. Figured I'd post some pictures before/after for those looking to do the same things.
I wanted 2 things, no "egg yolk" look in the front turn indicators, and I hate the yellow fog's - they needed to match the angel eyes
So that you guys can see the colors and comparison, I mounted my DSLR on a tripod prior to making the change to take the before pic, then just pulled the trigger to take the after. All images were shot in RAW then I made sure the color balance was identical between shots so as not to mis-represent the color changes
The first was accomplished with Solaris Invisibulbs - 1156 bulbs with 150 Degree Ofset - AKA: PY21W - I chose amber when lit
Before
After
Then the fogs - I went with GP Thunder H8 fog lights - the 7500K version
Before
After
I think the color just about perfectly matches the angel eyes
Btw - I was going to do a full DIY on how to change these, but they're so easy it didn't make sense to waste the time. Turn signals are accessed through a removable panel in the wheel well - a flat head screwdriver pries down two tabs in the top and pull it out - then reach in, twist and remove - reverse to replace. The fogs, pull 3 hex head screws out of the wheel well where the bumper meets the well lining, pull the lining back a little, unclip the fog light, twist and remove - reverse to replace
      12-22-2012, 10:07 PM   #4
Chris@codemybimmer
i put in 6000k and they match perfectly
      04-23-2013, 09:25 AM   #5
mattryan
mattryan's Avatar
Drives: 2022 M240i xDrive
Quick question for you guys... on the F30 does the LED brow match the AE's exactly or are the AE's a big bluer and the brow is a bit whiter?
Current: 2022 M240i xDrive
Previous: 2018 440i xDrive, 2012 135i
      04-23-2013, 10:03 PM   #6
Chris@codemybimmer
the brow uses the same led from the angel eyes to light it up
its the same color
      04-24-2013, 01:07 AM   #7
npgatech
npgatech's Avatar
11
Drives: 2012 BMW 335i
Where can you buy these bulbs? Are they easy to change? I have a 335i as well and I hate the yellow front fog lights. Also, is there a mod for changing the turn indicators from amber to color matched white?
      04-24-2013, 03:39 PM   #8
mattryan
mattryan's Avatar
its the same color
oh ya? I have an F30 as a loaner atm and the brow looks whiter for some strange reason...
      04-24-2013, 05:07 PM   #9
Chris@codemybimmer
If you go to realoem.com and look up the headlights theres only one led in there so im assuming its using the same leds
      04-25-2013, 12:20 AM   #10
utenigma
Not the case,
The LED that lights the angel eyes is a single high-powered LED, which is the part 1lyfe is referring to,
the brow is lit by a strip of LED's
If you doubt me, go into your garage, unlock your car from the keyfob and watch - both the AE's and brow light up, then a while later the brow turns off, then a few seconds the AE's turn off - they're different light sources
Check my signature, that's a pic with the AE's on, but the brow off
Personally, I haven't noticed a significant color temperature difference between the two, but I can imagine a world where BMW bought LED's from different vendors and different builds might have different variance in color temperature
      06-26-2016, 04:10 PM   #11
area51
area51's Avatar
Drives: 2015 BMW 335i Sedan
F30 coding for fog lights...
utenigma, What F30 coding did you have to do for the fog lights to work independently from the headlights? I can only turn ON the fogs when headlights are turned ON.
f30post
