F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Fog and side indicator change out - pics
Studio RSR
      12-19-2012, 02:59 PM   #1
utenigma
Drives: 2013 F30 335i 8SA M-Adaptive
Took delivery of my 335i yesterday, and <24 hours later it's been coded and now some of the bulbs have been changed. Figured I'd post some pictures before/after for those looking to do the same things.
I wanted 2 things, no "egg yolk" look in the front turn indicators, and I hate the yellow fog's - they needed to match the angel eyes
So that you guys can see the colors and comparison, I mounted my DSLR on a tripod prior to making the change to take the before pic, then just pulled the trigger to take the after. All images were shot in RAW then I made sure the color balance was identical between shots so as not to mis-represent the color changes
The first was accomplished with Solaris Invisibulbs - 1156 bulbs with 150 Degree Ofset - AKA: PY21W - I chose amber when lit
Before
After
Then the fogs - I went with GP Thunder H8 fog lights - the 7500K version
Before
After
I think the color just about perfectly matches the angel eyes
Btw - I was going to do a full DIY on how to change these, but they're so easy it didn't make sense to waste the time. Turn signals are accessed through a removable panel in the wheel well - a flat head screwdriver pries down two tabs in the top and pull it out - then reach in, twist and remove - reverse to replace. The fogs, pull 3 hex head screws out of the wheel well where the bumper meets the well lining, pull the lining back a little, unclip the fog light, twist and remove - reverse to replace
      12-22-2012, 06:17 PM   #2
AMPS
Drives: 2013 328i XDrive
These are great inexpensive mods! Definitely a must for me.
      12-23-2012, 02:34 AM   #3
ƒ°
ƒ°'s Avatar
101
Drives: ✚
Thank god... finally someone who understands color balance in photography.
      12-23-2012, 11:07 AM   #4
matt_435xi
matt_435xi's Avatar
Drives: Perfomance Model 3
excellent mods and pics! no error codes or any other issues?
'18 Tesla Perfomance Model 3 White on White Performance Upgrade Pkg & EAP
*RETIRED* 2015 435xi GC [f36] | 2012 335i [f30] | 2009 z4 35i [e89] | 2007 335i coupe [e92] | 2001 325Ci [e46] *RETIRED*
      12-23-2012, 03:31 PM   #5
RichardM
England
133
Drives: G21 M340i LCI
I've got the same with no problems. Why would there be when they are the same wattage as the original bulbs?
      12-23-2012, 09:27 PM   #6
utenigma
There aren't
If you try to replace bulbs with LED's (which have much lower resistance due to their low wattage) the car will think the light is out so you wire a resistor in series to make up for the difference.
Not to be confusing, but these lights aren't led, just different colored regular wattage lights
      01-13-2013, 04:24 PM   #7
lokito
lokito's Avatar
Puerto Rico
Drives: 335i ///M Sport
I have a pair of the Solaris bulbs coming on the mail... Any inputs on how bright or dimmed they are vs the ugly OEM bulbs. Thanks!
2013 335i ///M-Sport |6MT|Mineral Grey|DHP|PDC|HK|
      01-13-2013, 04:33 PM   #8
jrortiz
jrortiz's Avatar
Puerto Rico
34
Drives: 2012 328i
Nice, really nice. I will like to change the fog. You did some code for them too?
Black Sapphire Metallic / Premium Package / Technology Package / Cool Weather Package / Lighting Package / Harmon Kardon surround sound system / Vossen VSF/1 Matte Graphite
      01-14-2013, 09:48 AM   #9
utenigma
Haven't noticed any difference in brightness - they seem the same
No coding for the fogs - they're equivalent to the oem as far as voltage and wattage, just replacements as far as the car can tell
      01-14-2013, 10:04 AM   #10
Tsuyoi
Drives: 2013 F30 328i
I'm still a bit confused, are the Solaris bulbs LED or still just normal bulbs? Did you have to use resistors to prevent hyper blinking/error codes? I want clear bulbs that light up amber but haven't had much luck looking so far.
      01-14-2013, 03:16 PM   #11
lokito
lokito's Avatar
Puerto Rico
Awesome!!! Thanks!
      01-15-2013, 08:53 AM   #12
utenigma
The Solaris bulbs are normal bulbs - they're just coated with a reflective coating (think two way mirror) so when they're off, they look like they're made of chrome, and when they're on they're amber.
      01-15-2013, 03:51 PM   #13
prestonf30
Drives: 2015 m3
i just got in the mail today my solaris blubs but i went with the blue instead of the amber can't wait to see what they look like when i go home right now and also installing the gp thunder 7500k fogs i already have the gp thunder 3500 k yelllow but wife dont like them so she told me order the 7500k once she saw this thread lol
      01-22-2013, 02:58 AM   #14
giorgioarmani
Drives: silver m sport 335i & 19s
hi thanks for the great info. to be sure, is this the right link for the fogs? DOnt wanna be my usual dunce self and order the wrong ones
http://www.gp-thunder.com/GP_THUNDER_7500K_2010.htm
      01-22-2013, 07:06 AM   #15
utenigma
Yes, specifically you want the H8 35watt variety
      04-23-2013, 09:23 AM   #16
mattryan
mattryan's Avatar
Drives: 2022 M240i xDrive
Quick question for you guys... on the F30 does the LED brow match the AE's exactly or are the AE's a big bluer and the brow is a bit whiter?
Current: 2022 M240i xDrive
Previous: 2018 440i xDrive, 2012 135i
      04-23-2013, 10:10 AM   #17
1bad335
Drives: 2007 335I/ 2012 335I sportline
Just an FYI, I installed Solaris bulbs today. I went with the white when lit bulbs. I like them because I do not want the yellow lights when lit either. But be aware they are washed out for day time driving. The reason I was not concerned with this is because of the turn signals in the mirrors. Again, for me I did not want the yellow look on or off.
      04-24-2013, 09:42 AM   #18
superjoe
Drives: 2018 X3 30i M Sport (G01)
Do you have any pics of what the white bulbs look like both with your headlights on and with the turn signals flashing? I'm trying to decide between amber and white myself. Thanks!
      04-24-2013, 11:34 AM   #19
Joshhleee
///M Enthusiast
Joshhleee's Avatar
Drives: '12 F30, '15 x5 5.0, '15 M4,M5
can you pm me where you bought your fogs?
      05-02-2013, 05:48 PM   #20
1bad335
Sorry for the delay on pics and for the poor pics. Cell phone really sucks. I will get some pics at night too. But here they are. Again, signals are washed out in the daylight but because we have signals in the mirrors I was not at all concerned and was looking to get rid of the yellow lights. Fogs match the DRL and halos perfectly.
      09-14-2013, 04:24 PM   #21
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
Does they match the Xenon ?
      09-18-2013, 02:04 AM   #22
Sleepwalker
Drives: 2012 BMW F30 320d M-Sport
Looks great! Think I'll be using LED bulbs for my fogs :-)
f30post
