2010 2011 BMW 5 Series Forum F10 Anyone have issues with the doors sticking? |
01-02-2013, 11:29 PM | #1 |
Rep 42
I just got a 2013 550i and noticed an annoying little problem: After it rains, the passenger-side front door sticks when you try to open it. Basically, when I pull on the handle and apply a normal amount of force to open the door, it stays stuck closed. When I pull much harder (quite a bit more than I would normally pull), it opens. It feels like this is an issue with the rubber seals between the door and the frame sticking together. I haven't had this issue with the other doors, and this only seems to happen after it rains.
Anyone else experienced this, and any advice how to fix it? Many thanks! Doug |
01-03-2013, 12:42 AM | #2 |
Rep 114
Sounds like the door isn't properly aligned. If the fit isn't tight enough, water gets between the seal and the frame you have to break the suction to open the door. Get the dealer to check it for you.
01-03-2013, 01:50 AM | #3 |
Rep 1,210
Wow, I just got my 535 last month and the other day, after not driving it for a few days, I came to open my drivers door and it was stuck. Gave it a tug and it sounded like tape peeling. Only happened once so far!
01-03-2013, 12:02 PM | #5 |
Rep 42
Thanks, guys. I read online that applying some Armor All to the seals can prevent sticking. I applied some this morning and will report back whether it fixes the problem. If it doesn't, I'll have to follow OZDriver's advice and have the dealer look at it (hopefully, it doesn't come to that!).
01-06-2013, 06:06 PM | #6 |
Rep 42
So I Armor-alled my door seals, and then my car sat outside in some rain for a couple days. Tried the door today and there was no sticking at all. So -- fingers crossed -- the problem might be solved.
_____________________________
2013 550i (6-speed, MSport) |
01-08-2013, 12:43 AM | #7 |
Rep 556
Both my passenger and drivers side door have stuck after hot or wet weather since day 1.
2016 428i X Drive. Mineral Gray Metallic. Born 2/2016, Munich Factory.
Member BMW CCA Since 2008 |
08-31-2013, 02:34 PM | #8 |
Rep 156
Mine have not stuck closed - but they seem to bounce off the door seals unless you really slam the doors hard. IF I decide to buy a 2014 in the months ahead I will DEFINITELY add the soft close door option - NOW I know why!
Until then, I just tell my passengers to slam the doors and pretend that they are getting into a $70,000 Kia.
My opinions are free - you'll get exactly what you pay for!
Current: 2023 X5 45e MSport 2013 X1 3.5 MSport 1998 Z3 2.8 |
08-31-2013, 03:36 PM | #9 |
Rep 8,833
Mine does it because of the rubber gaskets around the doors. Doesn't matter if you have soft close doors or not (i have them). I'm sure you can get some rubber product like gummi phlege to fix it.
Alan
08-31-2013, 04:12 PM | #10 |
Rep 263
Mine did it once. I thought the remote was not working and the door was not unlocked. It was a 90 degree raint day. Car was at work. Only happened once.
Thanks for the reminder I do have gumiflege(sp)
2012 Tasman green metallic with oyster/ black interior. premium pkg, power tailgate, homelink, and park distance control. Premium sound: premium hi fi system and satellite radio,technology package:
Rear view camera and navigation,Comfort Access,heated front seats, BMW apps |
11-02-2013, 09:14 AM | #12 |
Rep 2,246
Aside from sticking, how about doors making a creaking / whining / gurgling noise upon open and/or close, when damp outside / after a car wash?
11-05-2013, 11:30 AM | #13 | |
Rep 308
Both of my front doors stick. Actually the passenger side door also popped open at ~30 MPH because the sticking was bidirectional - it was difficult to open the door, but ALSO difficult to fully close the door (required a hard slam). I think the dealer realigned the doors and it's been... better. |
11-05-2013, 11:31 AM | #14 |
Rep 308
Same with me - and as I just posted above, my passenger door popped open while driving (thankfully was caught by the secondary latch) because it was not fully closed/latched... thanks to the flawed seals.
2013 F10 535i Carbon Black M-Sport
2011 F10 535i Dark Graphite (Sophisto) Metallic (traded) 2009 Nissan GT-R (sold) BMW CCA # 493835 |
11-06-2013, 03:15 AM | #16 |
Rep 131
Mine as well! I have soft close. It is only when weather is humid/rainy. It doesn't get hot here so often ;-)
Both my F10 535i and F11 530d (non-soft close) did not have this issue.
Current: MY18 G11 750i (daily), MY14 Porsche 991 S (x51, m/7) (fun), MY17 Mini Clubman JCW All4 (GF)
Retired: MY14 F10 535d, MY11 F11 530d (temp), MY10 F10 535i, MY87 BMW E30 325i (fun), MY74 BMW E3 2500 (fun) (and more..) |
03-31-2015, 05:31 PM | #17 | |
Rep 1,207
My 535 is exhibiting this problem.
03-31-2015, 08:13 PM | #18 |
Rep 494
You can find it on Amazon.com. Search for Gummi Pflege
04-01-2015, 04:57 AM | #22 | |
Rep 10,185
Pflege = Care in German So "Rubber Care" Works wonders. You used to be able to get it from BMW Dealers, but I havent tried them for years since its cheaper at Amazon. You can also wax the paint side of the door with normal car wax to help prevent sticking even more. Also dont forget to clean there when washing the car. Its often overlooked.
BMW if you are reading, I need a job, Please. |
