E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Another P112C question w/ snapshot. HELP
Reply
      01-11-2013, 04:49 AM   #1
schctrg
Drives: e90 325i
Hi please let me know if you can help me.
I have a SES light on after a long drive from vegas. I have random rough idle and the following code pulled from an innova scanner. P112c, heres a freeze frame of when the light went off.
p112c
fuel sys 1 CL
fuel sys 2 CL
calc load(%) 29.4
ECT (F) 203
STFT b1(%) -3.1
LTFT b1(% -6.3
STFT B2(%) .8
LTFT B2(5) -3.1
ENG RPM 1786
VEH SPEED 30MPH
SPARK ADV 37.5
IAT (F) 75
MAF (LB/MIN)2.0
TPS (%) 22.4
      01-11-2013, 05:10 AM   #2
VirtuousWolf
Drives: 06 BMW 330i SP
No idea what half of that stuff means. But whenever someone says they got back from a trip and have a problem, possible bad gas comes to mind. Hopefully it's that! Good luck!
      01-11-2013, 05:13 AM   #3
schctrg
Drives: e90 325i
hmm. would bad gas do this?
      01-11-2013, 05:51 AM   #4
VirtuousWolf
Well I've never had a problem with the cars I've had, saab or bmw. But my parents have had this issue before with their lexus es. There were two different issues. The first one was when my dad was overfilling the gas tank, he does this thing where he likes to make the total be 42.42, or 51.51, etc. (not sure if it's ocd or if he does it for "security" reasons) Well overfilling it past the point of where the gas pump clicks would give him a check engine light, it took a while for him to figure out what was happening because of depending on the total he would only have to add a little bit of gas, or if he overshot it up to $3's too much. After a while the car would go back to normal.
Other times though though it would have a rough idle if he would put local style gas on road trips. I'm sure someone will chime in and say it all comes from the same place, and it probably does. But I like to go to newer style gas stations with a lot of traffic when I can't find a shell. He just puts whatever in it, lowest grade. But the car did not like the bad gas from those places.
The car is a tank though, 2001 es300 170k miles on it, no maintenance whatsoever, except for oil changes, air filter (like twice), brakes and tires. Lol no coolant change, brake fluid, tranny oil etc. It has had zero problems lol... Like zero it has never gone in for service ever. The car drives like a boat though, super floaty and the worst steering feel I've ever felt. Lol the rear suspension rattles but they don't wanna put anything in to it since they are going to trade it in. I'm trying to convince them to get either an X1 or a 328i.
I'm not a mechanic or anything, but I would say start small get some new premium gas from a nice place land dump some techron in. Oh and maybe clean your maf?
The real smarties on here are gonna want some more info, like the mileage of your car, transmission, spark plug history, etc. So it would probably help if you added that.
Hopefully it's something minor I'm sure all the guru's will chime in once they wake up.
Sorry about the rant haha, too tired to proofread it so sorry if I sound crazy
      01-11-2013, 06:47 AM   #5
schctrg
Drives: e90 325i
I should mention I cleaned up the maf already and also measured the resistance all within normal values. Still not sure what's wrong
      01-11-2013, 08:35 PM   #6
schctrg
Drives: e90 325i
So the light turned off. Don't worry about it anymore?
      01-12-2013, 04:08 AM   #7
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
P112C - O2 Sensor Negative Current or Positive Current Control Circuit/Open (Bank 1 Sensor 1)
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      01-13-2013, 03:38 AM   #8
VirtuousWolf
Glad it got resolved!!
Reply
e90post
