F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > kw v2 or v3?
GetBMWParts
      02-20-2013, 01:18 AM   #1
m2michael23
Drives: G82 M4 Competition
kw v2 or v3?
Can anyone point out the difference between these two? what should i get for my EBII 335?
      02-20-2013, 05:13 PM   #2
utenigma
Drives: 2013 F30 335i 8SA M-Adaptive
http://www.kw-suspension.com/us/kw_variant_2.php
http://www.kw-suspension.com/us/kw_variant_3.php
Basically, the v2 is height adjustable and rebound adjustable. The v3 is height, rebound and compression adjustable.
from KW's site
The compression phase adjustment is carried out at the lower end of the shock absorber via our patented multi-purpose valve. The large number of pre-set parameters of this valve allows for a wide range of adjustment for individual use. The unique low-speed compression adjustment significantly distinguishes this technology from any other. In this compression range, the driving behavior of the vehicle is drastically influenced. An increase of the damping power supports the vehicle already during compression and therefore avoids rolling and pitching. The directional stability is significantly improved.
      02-20-2013, 10:28 PM   #3
m2michael23
from KW's site
In your opinion, what would you get?
      02-20-2013, 10:55 PM   #4
utenigma
Depends on what you're going to be doing with the car and your knowledge of suspension changes
If the car is going to be a track rat and you want the greatest freedom with your setup, v3
If you just want it to ride harder and be lower with height adjustment v1
V2 sits in the middle - the compression is set from the factory so you don't muck it up too bad and you can stiffen the suspension with a simple adjustment.
You could decide to go v3 for the greatest flexibility with your setup, but depending on what you (or people that can help you) know, you may just be buying extra rope to hang yourself with
No matter which one you get they all look mean
f30post
