cdv delete
04-18-2013, 09:49 PM | #1 |
Rep 585
Drives: 2010 335i
cdv delete
So after a month of owning the new car, i realize how much I miss the Clutch Delete Valve on my old car. Anyone know where i can get this done here in MD... i know At-Speed is in the area, but they want true labor costs. Willing to cross into the VA if its worth it. Thanks in advance.
2010 335i Coupe / 6MT / MHD | FBO+ MMP S3 /AUBURN WDE / PATRIOTS / CELTICS / REDSOX
04-19-2013, 05:08 AM | #2 |
Rep 684
Drives: 09 328i Sport 6MT
Does it really make such a difference?
If so I may consider getting his done |
04-19-2013, 07:29 AM | #3 |
Rep 1,254
I'm in Howard County if you're willing to make the trip. I've done this many times and 9 of 10 require bleeding after installation. Not a big deal except accessing the bleeder is difficult without removing the slave cylinder and that's not easy without lowering the tail shaft of the trans. This is why shops try to charge for this.
04-19-2013, 12:11 PM | #6 |
Rep 585
Drives: 2010 335i
ahh thanks Clem! thought it was a simple removal.. Had it done on my old car when I was getting the coil-overs installed. got it. I Still need to make that trip to see you, just waiting on some other things to go wrong, that way we can knock it all out.
04-19-2013, 02:08 PM | #7 |
Rep 1,254
Cool. The CDV takes literally seconds to change. It's the air in the line that isn't fun the get out. Even when you clamp the line, some air usually gets in and it doesn't take much to render your clutch pedal limp.
04-23-2013, 12:58 PM | #10 |
Rep 585
Drives: 2010 335i
ended up getting it done local. Didnt buy the BMS one because its a simple un-hooking of the line from the stock one, then connecting back to the line without it.. no need for the modified cdv. Ran it for 51k on my last car.. no issues
