335i Buying Questions
04-28-2013, 03:20 AM | #1 |
Rep 149
Hi,
I currently have a Golf GTI Edition 30 and have just joined the forum as I’m looking at getting a getting an E92. As my current car has around 300hp, the 335i seems the best choice to me so that I can get a bit more luxury whilst keeping the kind of performance I’m used to! So I’m looking for an M Sport auto model, around 2007-8 (preferably one in the lower tax bracket!), which means the basic spec is pretty decent anyway, but have a few questions I am struggling to find the answers to… - Is iDrive different to Sat Nav or are they one and the same? I like my gadgets so I think it’d be a must for me! Also, even though I don’t use Navigation much, does the Professional Sat Nav offer a lot of benefits over the standard Business one? - I know 19” alloys were an optional extra, but is the suspension set up the same whether the car has 18” or 19”’s? I love the look of 19” M359’s so if I went for those would the car need lowering? - Is it fairly easy and cheap to change the dash trim? Ideally I want the brushed aluminum but obviously it narrows my options down again! - Are there any other spec options that are seen as ‘must haves’? - Mechanically, are there any things I should look out for when buying? I am slightly concerned reading about wastegate rattles, HPFP failures and cracked alloys! Oh, and I should probably ask this on another thread, but if you run catless downpipes do you have any problems come MOT time? Thanks! |
04-28-2013, 03:45 AM | #2 |
Rep 28
A few things I can maybe help you out on,
Cracks in the alloys happen with bmw 19" alloys and run flats, one of the reasons a lot of people change to non rfts also to reduce noise and increase the comfort of the car. Most common problems are the HPFPs, wastegate rattles, injectors and cracked alloys. Make sure when you buy the car it has a warranty also start it from when it's really cold and see if you can hear the wastegates rattle as they can't replace the gates and its usually a new turbo job if software upgrades don't work. Just for resale value make sure it has sat nav, there are 2 types cic and ccc, the better is ccc because it runs the maps off a hard drive opposed to a DVD which is in the dash so is a lot quicker. Must buys are get yourself a JB4 get the modding bug and enjoy |
04-28-2013, 04:21 AM | #4 |
Rep 1,431
I drive is the system which navigates the various functions of your BMW, Sat Nav, Phone, Radio, CD and car system information. Sat nav is just one function of I Drive.
It took me 4 months of trawling the web every day to find the right car. And I ended up blowing the budget wide open. Good luck! WM |
04-28-2013, 04:25 AM | #5 |
Rep 4,021
You can pay for an extended warranty through bmw.
Usually costs about £380 per year or £41 per month with breakdown cover as long as the mileage isn't too high. You can get a quote from here. http://www.bmw-warranty.co.uk/pages/cardetails.aspx Certainly worth the peace of mind. |
04-28-2013, 07:15 AM | #6 | |
Rep 81
Drives: 2007 LeMans Blue E92 335i
CIC is usually only available from 08/58 registered cars |
04-28-2013, 07:21 AM | #7 |
Rep 28
04-29-2013, 11:45 AM | #8 |
Rep 149
Cheers guys, I don't think I can really stretch to an 08 model so I'll probably have to settle with the older nav but as I don't use it much at all, it's not a major issue for me.
Extended BMW warranty sounds a good idea! |
04-29-2013, 03:19 PM | #10 |
Rep 172
i recently purchased an e92 335i coupe, i came from a 300 bhp gsi and i expected similar performance when i stepped in to the 335i ......you will not believe how different they are until you drive one...unless you already have !
The golf will feel faster and maybe more exciting if you like the feel of boost coming in hard but in reality this is the flaw in most hot hatches turbo engines. I was recently at santa pod in my 335i racing my friend in his seat leon cupra r 265 model, but pushing approx 290 bhp....compared to my gsi his cupra has a relatively linear power delivery but still you always get that thump as the turbo wakes up and the power comes in and imo this just makes front drive turbo cars hopeless ...and ive had a few. Side by side on the move our cars are near identical with the 335i just edging it by a narrow margin, but from a standing start or doing anything infact that involves traction in 1st and 2 nd gear and the incredible n54 engine just annihilates the cupra, racing up the drag strip the 335i pulled clear by a long way just because of its incredible traction and nasp like power delivery. I guess its personal taste but ive always enjoyed manual gear boxes, i tried an auto but i felt a tiny bit like a passenger, the manual box seemed to give me more control and bring the car to life for me, mine has the 19 inch alloys and its an se model. I know everyone prefers "msport" models but the se has fantastic handling, i believe the car is already 25 % stiffer than the equivalent 335i saloon and so the suspension is pretty darned firm as is, i can't imagine what an msport would feel like with 19's on. When the car was released it was compared to the e46 m3 and it was superior in almost every way, faster , better brakes and shorter stopping distances, it matched exactly the m3 through the handling tests and the verdict was usually that the e92 would beat the m3 around a lap of a track if only it had an lsd...so the se is no lardy 2nd rate car! If you haven't already then i would suggest you try a few different ones before buying so you can see what the different models ride like. Mine had the abs hydraulic pump fail which is expensive and quite common.....deffinitely get a long warranty...i wouldn't buy private even if the car was mint unless it came with warranty. I had only had mine 1 week when the abs pump failed and stratstone quoted 2300 quid to fit a new one, thank goodness i had warranty.!! |
04-29-2013, 03:27 PM | #11 |
Rep 4,021
There shouldn't be any handling difference between the E92 335 models.
All E92 335 models have the same sport suspension unless the buyer requested not to have it. |
04-29-2013, 03:28 PM | #12 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
335i SE E92's have M Sport suspension as standard. I think the same went for 335d's too. You can sometimes get a lot more car/spec for your money in SE trim than M Sport so don't rule them out!
04-29-2013, 03:29 PM | #13 |
Rep 149
Thank you, that's great to read! Yes at the moment I'm used to the boost coming on hard and spinning the front wheels up even in 4th at 80mph+ ! It's a fun car, but I'm after a bit of a change and I don't doubt that the RWD 335i would be a very different beast but still fun!
The DSG box was the first auto I've had but for me I prefer it as I can be lazy most of the time but then flick it into manual mode when I want to use the paddles and have a bit more control, that's why I'm leaning towards another auto. I will have a couple of test drives but I think I've already made my mind up! |
04-30-2013, 07:39 AM | #14 | |
Rep 7,690
Drives: 335i SE Coupe Space Grey
I would suggest you do some more reading on the engine. The n54tech forum got some good info. Suspension will be the same as msport unless the owner has deleted this option. |
04-30-2013, 10:44 AM | #15 |
Rep 1,271
Drives: 335i (sadly gone)
If you are going for a 335i you pay a big premium for Msport but get relatively little extra for it.
04-30-2013, 11:48 AM | #16 |
bimmer newb
15
Rep 334
I loved the look of the 19" M3 wheels, sport suspension, M door sills and dead pedal, aero pkg., anthracite headliner, etc. etc., and felt that with this pkg. I would have few cosmetic upgrades to add. Whiter looking AE's, brighter fogs, and the JB4 were the only mods I felt that the car needed.
04-30-2013, 11:55 AM | #17 | |
BM Noob
24
Rep 975
Quite rare but will probably be closer to your DSG than the Auto box. |
04-30-2013, 03:00 PM | #18 | |
LSD - No, you're not seeing things
72
Rep 3,302
Not all FWD hatches are equal. The Reno I have remapped (standard ATB diff) has no issues with traction at 300+ BHP. The power output is not on/off and is almost flat from 2k up to redline. The Scirocco R was on the shopping list until I drove one hard. Messy, ploughs off roundabouts without any effort. Needs diff. The tuned 335i tuned really needs the LSD, and more importantly some better brakes!
05-01-2013, 06:53 AM | #19 | |
Rep 5,681
I'm sure you could sort most if not all of these shortcomings by spending money with someone like Birds but in my experience a standard 335i is no match for an E46 M3. Don't get me wrong, I like my 335i and it's well suited to my requirements at the moment; however, an M3 it isn't! |
05-01-2013, 01:55 PM | #20 |
Rep 149
Lots of opinions!
When you say DCT vs Auto - I understand the auto is a single clutch so will be slower but it still has paddles so can be put in a manual mode can't it? All DCT 335i's I've seen for sale are over my budget unfortunately! I also understand there's not much difference between the SE and M Sport models but I do prefer the body styling of the M Sport, and I'm prepared to pay the extra for that and the other little M Sport touches! |
05-01-2013, 03:24 PM | #21 | |
Rep 5,681
05-01-2013, 03:41 PM | #22 |
Rep 159
I was in the same situation you were a month ago. I just purchased my 2007 e92 coupe two weeks ago.
A few things I did that helped with my buying decision -Check the average MPG on the head-unit. That will give you an idea of how hard it was driven and what kind of miles were put on the car. Anything above 20mpg should be a fair indicator that the car has mostly highway miles or wasn't driven terribly hard. -If you can, look for a car that has the extended warranty. Many of the 2007s are starting to run out of the 6year/100k warranty, but even if it only has a few months left, you can assume the vehicle most likely was taken care of. -Check the front/rear bumpers. I passed on a car because it was obvious it had been resprayed. There was nothing on the carfax (and usually there never is). -Drive the car at highway speeds. Check to see if there is any kind of steering wheel vibration at 60+ mph or when you brake. The front control arm bushings are a common wear part on these cars. You can swap to M3 control arms for about $200, but it's still something to check. -Assuming it has the Logic7 sound system, check the equalizer settings. If they're all the way turned up, the owner probably didn't know what they were doing and were probably blasting their stereo pretty hard. -Things like dirty exhaust tips aren't the worst thing in the world. They are easy to polish up and the N54 seems to run pretty rich in stock form. As a result, carbon build-up is pretty common. -Consider paying BMW to do an inspection on it. I had the seller pay the $180 it cost to do it. It wasn't terribly thorough, but they did note the control arm bushing wear I mentioned above. |
