M3 Strut brace and sway bar
05-18-2013, 01:29 AM | #1 |
Rep 136
I'm thinking about improving the turn in on my E92 msport 335i which currently has no suspension mods. The E9x M3 strut brace and E93 sway bar seem to be the best way to start and not spend a huge amount.
Has anyone done both? Is it worthwhile doing both or is doing just one of the upgrades sufficient? I will probably leave everything else as is so wondered if it's worth doing this mod. Cheers
05-18-2013, 02:28 AM | #2 |
Rep 3,200
Drives: E92 325i MSport Coupe
On the topic of the M3 strut brace, I see you have MSPort spec so you'll already have braces in place. Substituting the M3 braces will have minimal effect IMHO.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
05-18-2013, 03:28 AM | #3 | |
Rep 1,518
On the second point of the e93 ARB, I've read quite a few posts about it helping to dial out some of the understeer felt on the standard setup. I have the e93 m3 front ARB and e92 m3 rear and can say that it feels much better than the standard setup. |
05-18-2013, 06:23 AM | #4 | |
Rep 3,200
Left Wishbone link -31102283577 Right Wishbone link -31102283578 Left Tension link - 31102283575 Right Tension link - 31102283576
05-18-2013, 04:16 PM | #5 |
Rep 793
I went from the standard E92 strut brace to the M3 one and there is a noticeable difference. Not only does the M3 brace fit using all three nuts at the strut tower end, it also bolts up to a cast U piece at the bulkhead, whereas the stock items just have a slot that slides over a bolt. I got rid of a couple of dash rattles by fitting mine, which shows how much rigidity it adds.
2021 G21 M340i XDrive | ACS springs and spacers
Previously 2019 VW Golf GTI Performance | H&R rear ARB Previously 2007 E92 335i SE auto | Quaife LSD | Birds B3 ARBs | Evolve Stage 1 |
05-18-2013, 04:58 PM | #6 |
LSD - No, you're not seeing things
72
Rep 3,302
Of course the easiest and cheapest way is wider front rubber
Firming the front bar alone will make matters worse, not better. It might 'feel' better but you'll be even more prone to pushing wide. Same with the strut braces, its about the last thing to do really. It adds feedback/feel but wont make you turn any faster. More front camber is best after more rubber if its understeer on entry to tight corners you are trying to fix. Where is the problem occurring?
05-19-2013, 02:50 AM | #8 |
Rep 8,972
The standard brace is slotted push-in at the bulkhead end, so it has no extension resistance.
As said by seanblee the M3 uses rigid multi bolt cast fixings and is a solid 3 point brace, lots of creaks removed with the extra rigidity. Fitting a thicker front ARB will just increase understeer and reduce front grip further, you need to increase the rear stiffness to increase turn in. It might make it 'feel' sharper at the front, but it will make it worse. |
05-19-2013, 06:35 AM | #9 | |
Rep 3,200
05-19-2013, 02:27 PM | #10 |
Rep 8,972
05-26-2013, 08:29 PM | #13 |
Rep 3,049
Drives: 2009 BMW 335d
