06-08-2013, 06:51 AM | #1 |
Rep 1,135
Give Us An F30 Sway Bar Already
We have body roll. We need a sway bar. Now.
We have body roll. We need a sway bar. Now. We have body roll. We need a sway bar. Now. We have body roll. We need a sway bar. Now. We have body roll. We need a sway bar. Now. We have body roll. We need a sway bar. Now. We have body roll. We need a sway bar. Now. It's a metal bar. Let's go already. |
06-08-2013, 07:51 AM | #2 |
Rep 3,780
I have been stalking Turner.com for it's release
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
06-08-2013, 09:00 AM | #3 |
Rep 1,135
Let's take it to Kickstarter.
What's it cost to make a metal bar in China? $10? It's got to be the most necessary and anticipated sway bar in automotive history, no? Is there a car with more enthusiasts out there? A car that needs body roll reduced to restore it to its prior glory more? I'm sick of waiting, not like you can just drive up to Dick's Sporting Goods and buy one in a parking lot or anything. |
06-08-2013, 09:11 AM | #4 | |
Rep 3,780
06-08-2013, 09:41 AM | #5 | |
*Bimmerpost Plasti Dip Guru*
83
Rep 1,174
Drives: E53, E46-M3, E70, F25-X3
06-08-2013, 10:24 AM | #6 |
Rep 1,135
We need a sway bar. Give it to us.
We need a sway bar. Give it to us. We need a sway bar. Give it to us. We need a sway bar. Give it to us. We need a sway bar. Give it to us. We need a sway bar. Give it to us. I feel a little bit better now. |
06-08-2013, 01:15 PM | #7 |
Rep 5,373
I'm sure BMW will charge $299
///| g87 | f87 Comp | g29 M40i | f97 Comp | f80 Comp | f80 | f30 | e92 | tt | S5 | e92 | 350z | e90 |
06-10-2013, 10:43 AM | #9 |
Rep 3,780
They do not offer swaybars, only that you use 704 Sport bars if your car is not a Sport/MSport to start with.
06-11-2013, 04:18 PM | #11 |
Rep 148
06-11-2013, 04:44 PM | #12 |
Rep 3,780
Same. Both swaybars, the sports bars are specific to the MSport/Sport 704 suspension and are larger in diameter.
06-11-2013, 04:51 PM | #13 |
Rep 148
06-20-2013, 12:48 AM | #14 |
Rep 399
These cars need sway bars asap! miss my Hotchkis sways on my E46, by far the best suspension mod ever for me.
European delivery 9-19-2012
06-30-2013, 08:13 PM | #16 |
Rep 1,044
Trying to understand here. I have the regular "non-sport" suspension.
EDIT: I'm actually not too dissatisfied with the stock suspension in the car. I can feel some amount of road, yet it is not too harsh (so I can go over bumps pretty fast without bottoming out). However I do notice the car has body roll which I would like to address without making the suspension too harsh. |
07-01-2013, 09:16 AM | #17 | |
Rep 573
Drives: 2013 F30 335i 8SA M-Adaptive
Both standard and sport have front and rear sway bars Std suspension front sway is 25/21.1 mm, Sport suspension front sway is 25/22.2mm Std suspension rear sway is 12mm, Sport suspension rear sway is 13mm Sport and M-perf suspension sways are the same Quote:
Changing to a coil-over, changes the Spring and Strut, which alters the vehicle's compression and damping characteristics, which will (likely) make the car ride stiffer. It will also (likely) limit roll, due to higher spring rates (springs are harder to squish so car doesn't roll onto them) and (likely) lower vehicle height (car has less suspension travel so can roll less at the limit).
07-01-2013, 09:30 AM | #18 | |
Rep 3,780
Swaybars directly address body roll and are the bang for the buck suspension modifications.
07-01-2013, 08:22 PM | #19 |
Rep 944
Isn't installing sway bars on the F30 quite a serious undertaking? I am sure I read somewhere on here that someone upgraded to the m performance suspension and had to upgrade the sway bars to the m sport one and it involved quite an amount of work
2013 Alpine White 328I M Sport ARRIVED
07-02-2013, 10:00 AM | #20 | |
Rep 3,780
I have the 704 Sport setup, won't be touching the front bar.
07-04-2013, 10:26 PM | #21 | |
Rep 1,044
07-05-2013, 05:57 AM | #22 | |
Rep 603
Not looking at all the other models. But it seems there is quite a bunch of sway bars on the different F30/F31 models (I hope, I did read that correctly in the online catalogue.) 335i F30 regular Suspension = Sway Bar 25mm/21.2mm Part# 31 35 6 792 118 335i F30 M Sport Suspension = Sway Bar 25mm/22.2mm Part# 31 35 6 792 119 335i F31 all Suspension = Sway Bar 25mm/22.2mm Part# 31 35 6 792 119 328i F30 regular Suspension = Sway Bar 24mm Part# 31 35 6 792 124 328i F30 M Sport Suspension = Sway Bar 24.2mm Part# 31 35 6 792 125 328i F31 all Suspension = Sway Bar 24mm Part# 31 35 6 792 124 316i F30 regular Suspension = Sway Bar 24mm Part# 31 35 6 792 111 316i F30 M Sport Suspension = Sway Bar 24.6mm Part# 31 35 6 792 112 316i F31 all Suspension = Sway Bar 24mm Part# 31 35 6 792 111 As far as I know, sway bars are made out of feather steel. I don't know if the 328i sway bar just varies in size, or if it's also another (harder) type of feather steel that's beeing used for the M Sport Suspension Sway Bar. (or will just 0.2mm more thikness make any difference? ) I don't know if the sway bar of a 335i would fit on a 328i (maybe someone else can answer that), but if so, that's maybe worth giving it a try for 328i owners complaining about body roll. |
