F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > M Sport brakes Option
Extreme Powerhouse
      06-13-2013, 04:57 AM   #1
jetbill
jetbill's Avatar
198
Drives: G80 M3
As it relates to the bmw performance brake kit, the option appears when purchasing a new F30 for $600, the two kits are the same or different?
Basically the factory optioned brake upgrade is the same as the BMW big brake kit upgrade?
      06-13-2013, 12:33 PM   #2
infinitigor
Drives: 2023 M3C, 2010 E350
huh, where do you see an option to add the performance brake kit for $600 ?
      06-13-2013, 12:54 PM   #3
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
apparently the US gets the same option as EU/Canada now...pisses me off, that we had to spend $2500 to get them AFTER the fact if we purchased before 2014....
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      06-13-2013, 01:16 PM   #4
taichi
taichi's Avatar
Drives: F30 & F25
wow that really sucks for M-Sport Owners..
      06-13-2013, 01:50 PM   #5
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
You still have the "better" discs that cost about $200 each.
      06-13-2013, 03:33 PM   #6
momo3605
Drives: M340i LCI, 718 GTS 4.0
Where is this option?
      06-13-2013, 07:20 PM   #7
jetbill
jetbill's Avatar
198
Drives: G80 M3
http://www.f30post.com/forums/attachment.php?attachmentid=866109&stc=1&d=1369320 586
Page 9 of the 2014 guide.
      06-13-2013, 07:51 PM   #8
momo3605
OH wow, totally got jipped But I assume that gets you the 2 piston front calipers and stock rotors. Vs the M perf brakes which get you 4 piston front/2 piston rear and dimpled/slotted bigger rotors?
      06-13-2013, 09:27 PM   #9
bmrm396
Drives: 2018 F80 M3cs
No it actually gives 4 up front and 2 in rear
Formerly addicted to e46fanatics
Formerly addicted to e90post
      06-14-2013, 04:33 PM   #10
momo3605
So who will they sell the M perf brakes too?
      06-14-2013, 04:45 PM   #11
bmrm396
people who actually track or are really gullible enough to care about those slotted/dimpled discs ... i dunno
      06-27-2013, 01:57 PM   #12
avantix
avantix's Avatar
Drives: 2019 M4CS Lime Rock Grey
If one already has the blue M Sport brakes on an MSport 335i can you simply add the drilled/slotted rotors as a direct replacement to the standard disks?
2019 M4CS Lime Rock Grey, MP HAS, GC camber plates, MPE
      06-27-2013, 02:42 PM   #13
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
Yes, but it is costly, last quote I got was in the $800 region. I contacted AdamRotors and he could supply replacements for $500 incl shipping.
      06-27-2013, 03:57 PM   #14
avantix
avantix's Avatar
Awesome. I'm guessing plug and play one hour install with no reprogramming since calipers aren't being touched except for possibly a bleed?
f30post
