F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > JB4 stage 2 on my 335i , how can i know if i can install it in my car?
Studio RSR
      06-22-2013, 10:42 PM   #1
pelo911
Drives: 991 GT3
i heard something about pneumatic solenoid , not sure
i want also to buy Down-pipe and intake
what are my best option?
downpine: make a lot of noise and can't be used for daily car?
intake: how often need to oil it ?
Thanks
      06-22-2013, 10:45 PM   #2
pelo911
Drives: 991 GT3
      06-23-2013, 12:06 AM   #3
D.Mathys
Drives: 2013 335i
You need to check to see if you have an electric of pneumatic boost solenoid. It's on the other side of the engine above the turbo. There is a picture of it on the BMS website. If you have the one that matches the BMS picture you are good.
For downpipe, there are only a couple on the market, I believe the ER catless and the Challenge catless and high f low cat. I went with the ER and love it. It is a bit louder but sounds good and you can definitely use it on a daily driver.
Same deal with the intake, only a couple on the market, I believe AFE and Injen both make one for the F30. Also there are a couple drop in filters available. All can be either dry or oiled and have different cleaning/oiling requirements. I ended up going with an AFE drop in until the BMS intake is ready. I heard its in the finally stages and should be available soon.
      06-23-2013, 12:56 PM   #4
pelo911
Drives: 991 GT3
thanks for your reply
http://www.burgertuning.com/N55_Stage2_Jb4.html
i can't find any picture
can you direct me?
i have no idea where to look under my car
i found only this pic , it's not F30 engine:
http://www.carblog.co.za/wp-content/...six-engine.jpg
      06-23-2013, 01:36 PM   #5
D.Mathys
Drives: 2013 335i
http://smg.photobucket.com/user/NICK...667f1.jpg.html
If you are in front of the car looking at the motor, it is on the left hand side. Connection with the split loom is the top.
      06-23-2013, 03:24 PM   #6
pelo911
Drives: 991 GT3
i took a pic
so i can use the JB4 without issues ?
      06-24-2013, 01:39 AM   #7
D.Mathys
Drives: 2013 335i
You should be good.
      11-25-2013, 11:37 AM   #8
ossanboy
Drives: F30 335i
I just installed my JB4 stage 2 in F30 335 today, European version.
I cant find the solenoid in the left side. I do find similar one near the IMAP.
So I plug the blue cable in it, did I do the right thing?
Here is the image.
Can someone help?
Thanks
      11-25-2013, 01:10 PM   #9
ands
Drives: E90 335i
So if you don't have the solenoid what options do you have for a tune?
      11-25-2013, 01:41 PM   #10
tdizzle
Drives: 2017 F80 ZCP
Same as before actually. You can use the JB4 without that connection. Stage 1 actually tells you not to connect it. Stage 2 could go either way. There is a slight gain by using it but not sure you'd notice it unless you're going all out on mods.
      11-25-2013, 01:47 PM   #11
ands
Drives: E90 335i
What about the guys running Map 7 with e85, do you need this solenoid for that?
      11-25-2013, 02:56 PM   #12
tdizzle
Logically, the answer is yes but the car may be making less boost. I say logically, since Stage 2 would otherwise be useless if it required that connection for any map besides map 1.
When Terry released a recent software update he said the update was specifically a tweak for those cars with the solenoid connected.
I'd ask BMS if you are concerned, I'm sure they are willing to answer any questions you may have. There are people running it without the solenoid connected for sure though.
f30post
