      06-25-2013, 10:59 PM   #1
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
12 Volt Power...
Okay, just throwing this out there....
Why in the Year of Our Lord, 2013, can't we have a much more compact form factor for 12V power ports. I mean hardly anyone smokes any more, so why can't the Auto Industry convert over to a much more compact standard 12 V power port other than a stupid cigar lighter socket - Just sayin'
      06-25-2013, 11:02 PM   #2
NemesisX
Drives: '19 Infiniti Q60S
That was quite random...
      06-26-2013, 03:38 AM   #3
b0bab0i
Drives: 03 TiAG z4 3.0i w/ hardtop
Most cars come with USB Ports
      06-26-2013, 07:01 AM   #4
Efthreeoh
Maybe, but there are 6 types of USB connectors and the max power is 500mA at 5 V.
      06-26-2013, 07:34 AM   #5
Sedoy
Drives: F10
All standard USB have one similar plug otherwise it's not USB. Also why would you need more power? Trying to charge Tesla or use your hairdryer...?
      06-26-2013, 07:45 AM   #6
Efthreeoh
Well that's just the Standard Type A USB plug. There are 5 other types. USB is a data protocol standard, not a single plug-type standard. The other plug types are: Standard B, Mini A, Micro A, Mini B, Micro B. Just to be a geek about it.
      06-26-2013, 08:13 AM   #7
Sedoy
Drives: F10
Yep that's true, but usually like 95% of USB cables end with the Standard Type-A USB plug. For example if you have a USB port in the desktop, laptop, TV, car, radio, etc. normally you will see Standard Type-A USB receiving port.
      06-26-2013, 03:43 PM   #8
Efthreeoh
We're drifting here. Back to the point, which is a different (i.e smaller/less obtrusive) form factor for 12V DC power other than a cigarette lighter, which size is defined by the size of a 1940's cigar. The industry should develop a new standard for a 12 volt power conector. USB has a max voltage of 5V and 500mA, which is hardley enough power to run something like a tire inflation kit, which many people here keep in the trunk in place of run-flats.
