N52 Oil Leak?
07-03-2013, 09:06 PM | #1 |
Rep 654
N52 Oil Leak?
This is a N52 with over 80K miles. I had my valve-cover gasket replaced at 50K and around the seal is clean and grime-free.
I also had my exhaust vanos leaking and it made the surrounding area grimy and oily. I replaced it and clean the area around it. However, I recently notice the area below the vanos, near the main pully, it is very dirty. Grimy and oily. I also see there could be some sort of a seal there that could be bad. Can anyone comment? Thanks in advance |
07-04-2013, 03:26 AM | #2 |
Rep 3,200
Drives: E92 325i MSport Coupe
Weeping head gasket? BTW love the cutaway engine pic. Got any more you could post?
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
07-04-2013, 05:54 AM | #3 | |
Rep 654
Sorry, not my image. Found it on Google. Last edited by sle39lvr; 07-04-2013 at 06:51 AM.. |
07-04-2013, 06:52 AM | #4 |
Rep 654
Car is under CPO warranty. If it's a head gasket leak, I want to approach them with confidence since they will do whatever they can to get out of it.
Here are my own images to supplement: Any thoughts? Last edited by sle39lvr; 07-21-2013 at 11:51 AM.. |
07-04-2013, 08:41 AM | #5 |
Rep 3,200
Having seen your additional pics, I'd revise my view. Not very oily in my opinion. I feel this could be left over run-down from before you had your valve cover gasket replaced. I think the grime (at the front at least) is rubber crumb from the drive belts. If it was mine, I would thoroughly clean the area down and see of the 'leak' reoccurred. Just my five cents...
07-04-2013, 09:28 AM | #6 |
Rep 18,801
Hate to tell you this, but engines get dirty after 80,000 miles of use. Live with it. If you take that car in as a warranty claim, they are just going to laugh at you.
07-04-2013, 05:06 PM | #7 | |
Rep 654
Either way, I guess I will Simple-Green it tonight and see how it goes in few months. |
07-05-2013, 12:07 AM | #9 |
Rep 4,732
Drives: Alpine White '13 550i
07-23-2013, 06:33 AM | #11 |
Rep 1,076
07-23-2013, 11:56 AM | #12 |
Rep 654
07-23-2013, 05:42 PM | #13 |
Rep 1,076
