      07-13-2013, 01:45 AM   #1
lorne
Drives: 2014 BMW x1
Missing Factory Supplied Option/Part
My new 2014 BMW X1 is missing the switch to turn on the heated steering wheel. It may also be missing the heated steering wheel capabilities as well (not sure). Has anyone run across an example where a factory supplied option/part is missing. BMW has offered a couple of hundred dollars in compensation. What do you think?
Thanks for your comments.
      07-20-2013, 09:01 AM   #2
Beemn
Drives: 2013 X1
Being a newbie myself I may not have this right, but, if it was supposed to have the heated wheel and doesn't are there other things in that package that is missing? Mine was part of the Winter package and also had heated seats and headlight cleaner. If they are also missing, you're missing the entire package which costs $700.
      07-20-2013, 11:53 AM   #3
Mach1er
Mach1er's Avatar
90
Drives: '13 128i
If they built you the wrong car, methinks you should have them go back and build you the right one. You're paying for service, not just the option.
'13 128i | 6MT | SGM | Black Boston | Black Gloss | Lighting | Premium | Tech | HK | Anti-Theft | [CDV-Delete | Clutch Stop | 30% Pinnacle]
Ordered 2.23 | Production Begin 3.7 | Ends 3.15 | Released to carrier 3.18 | At port 3.19 | Departed 3.23 (K-line to Brunswick) | Arrived 4.7 | Truck 4.12 | Dealer 4.19
      07-20-2013, 01:52 PM   #4
Stohlen
Drives: AW 135i
2008 BMW 135i  [5.66]
Okay so this is whats called a "misbuild" from the plant in which your car was produced. When this happens and the car makes it past tech inspection to the dealer, the dealer is not at all liable for the vehicle's issue. Which makes me wonder why the dealer offered you money as compensation rather than this being a warranty claim and no cost to them, because it is a warranty issue. BMW should work with you to properly retrofit the car or replace it with one that is built to the proper specification, depending on the extent of the problem. This is a common practice across all brands.
      07-20-2013, 09:41 PM   #5
Twix
Twix's Avatar
Drives: 2011 e91
One thing to note. M sport package deletes the heated wheel even if you have the cold weather option.
