Bms Powerbox map 3
08-06-2013, 05:17 PM | #1 |
Rep 177
Bms Powerbox map 3
I've had my Powerbox installed for more than a year now and enjoy the throttle response tremendously over the stock throttle. I've been using Map 2 because it's just right for me. Recently I tries map 3 just for the heck of it and immediately felt the difference in the response.
However something nasty happened several times when I got WOT in map 3. The car goes into limp mode when I go hard on the gas when the engine gets to about 5000-6000 rpm. I get the orange engine light and have to restart the car to make everything go back to normal. It's almost as if map 3 overloads the computer or something. Anyone else experience this kind of behavior with their Powerbox?
08-07-2013, 05:33 AM | #2 |
No 55mph
1622
Rep 8,477
No problems here - I set my PB to Map3 from the beginning (2yrs ago) and have never changed, or tried any of the other settings - car has never had a problem...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
08-07-2013, 08:54 AM | #3 |
Rep 2,366
Drives: 2007 E90 323i (Cdn)
Not quite sure if I'm having the same issue since I installed my PB at the same time as my Air Intake, so it's a bit hard to isolate what the cause of the error is.
I got the two parts installed one day apart, and the car has run fine for the last 6 weeks or so. A couple of days ago, I was at WOT (which I don't do often, but I have done a few times since the install) and the Check Engline light came on. I don't have massive power loss, but I do notice that the power band isn't smooth, a bit jerkey. If I'm not at WOT, it's harder to notice the jerkiness. I'm on PB Map 2, and I'll start investigating my intake first (ensure tight connections, clean MAF, etc.). Anyone have any other suggestions? |
08-07-2013, 02:41 PM | #4 |
EL JIMMY NEURON
44
Rep 1,180
Make sure none of the pins from the PBX to ECU have come loose.
2007 Jet Black E90 328i
Thread: http://www.e90post.com/forums/showthread.php?t=825249 Instagram: manutd_as |
08-07-2013, 02:46 PM | #5 | |
Rep 177
08-07-2013, 02:50 PM | #6 |
OPN DIFF
478
Rep 1,910
Drives: 10' E90 M3 6MT LB
I have been on map #3 since I installed it, no problems here.
'10 LB E90 slicktop/speed cloth/6MT ex. '06 330i 6MT & '10 n54 6MT Msport Autocross vids https://www.youtube.com/user/tigermack https://www.instagram.com/tigermack |
08-07-2013, 02:51 PM | #7 |
EL JIMMY NEURON
44
Rep 1,180
Oh, there ya go. That might be it. When I had mine on I wrapped a small amount of painter's tape to keep the pins locked together.
08-07-2013, 03:02 PM | #8 |
No 55mph
1622
Rep 8,477
I actually used heat shring tubing on all connections in my install instead of tape - tape will dry up and fall off - especially accelerated when exposed to heat...
08-07-2013, 03:05 PM | #9 |
OPN DIFF
478
Rep 1,910
I didn't use any of that... don't you just plug them in???
08-07-2013, 03:14 PM | #10 |
EL JIMMY NEURON
44
Rep 1,180
Yeah, but I taped them up just so I wouldn't have to go back and be checking all the time.
08-07-2013, 03:20 PM | #11 |
No 55mph
1622
Rep 8,477
Did you have the instructions when you installed yours? Cause they clearly state to use tape on all the connections to eliminate the chance that they may come apart.
I just went a step further and used shrink tube which is better than tape
08-07-2013, 05:22 PM | #12 | |
OPN DIFF
478
Rep 1,910
08-07-2013, 07:06 PM | #13 |
EL JIMMY NEURON
44
Rep 1,180
Nice. I just put tape anyways to have peace of mind. haha
