08-11-2013, 11:21 AM | #1 |
![]() 12
Rep 45
rx7 with ls1 swap
i'm still debating on buying a ls1 swap rx7 to add to my collecton since i know rotary can be a pain in the ass to rebuild ever 50k ugh.. i need more suggestion nay or yay?
2008 335xi cobb stage 2+FMIC
1995 Supra turbo-800hp 1991 Acura nsx |
08-11-2013, 01:22 PM | #3 |
The mod bug has bitten.
![]() 25
Rep 562
Drives: 2008 M3 Sedan
Sorta kills the handling of that car. The rotary is so small and light. Replacing it with a small block V8 will destroy the fun of the car IMO. RX-7's were blast because they were light, 50/50 weight distribution and the stupidly high-revving motor.
I think you're better off spending the dough on a nice 3-rotor wankel and putting that in there. Do all the cooling mods you can and the engine will easily run 100-150k miles. Just keep oil in it and keep the temperatures down. |
08-11-2013, 02:00 PM | #4 | ||
Rep 688
A stock aluminum LS-motor with accessories comes is only 27 lbs. heavier than a 13B-REW with turbos, IC, and all accessories. Most LS-swapped FDs end up around 2700-2800 lbs. with a full interior and 50/50 distribution, in line with a bone stock example. Many also remove AC, PS, ABS, etc., and more weight can shed easily. It's very easy to get a street-driveable weekend track-car in the 2600s. Here are the corner weights of one's full-interior, caged FD with a full tank of gas and him sitting in it... ![]() Quote:
Anyone who tells you how reliable an RX-7 can be after "reliability mods" is either delusional or lying to your face. I know this because I have owned one. I bought a pristine 94 FD with 56K miles as a weekend car in 2005. I did everything you could imagine in terms of "reliability" and "cooling" mods. I have money, and I didn't skimp on anything. It was a complete nightmare. The FD RX-7, while among one of my favorite cars ever made and in history as one of the greatest sports cars ever made, is a complete and utter piece of shit. Unless you swap a V8 in it... Not only are LS-swapped RX-7s worlds more reliable and simple, the motors themselves are bombproof. Options are also endless...you can go with a stock LS1 which you can buy for pennies and have a wonderful and amazingly fun 300RWHP 2700 lb. sports car, or go all out and build a 600+ RWHP all-motor LS7 and have a complete monster. Approved. |
08-11-2013, 02:46 PM | #5 | |
![]() ![]() 25
Rep 380
Drives: 2012 135i
I've seen this same motor in a Miata and it flat out demolished everything at the track. |
08-11-2013, 05:22 PM | #6 | |
![]() 12
Rep 45
thanks I knew rotary had problems... I thought about buying it and supercharge it
08-18-2013, 12:27 AM | #10 |
Rep 688
08-18-2013, 01:11 AM | #11 |
![]() 4
Rep 47
I meant if he wants to buy an RX-7 regardless. I would never buy a rotary RX-7, though.
08-18-2013, 12:15 PM | #12 | ||
![]() 25
Rep 1,033
