Will 4 wheel alignment fix outer edge tyre wear?
08-20-2013, 03:05 PM | #1 |
Rep 298
Hi, both my E91 and a colleagues E92 are wearing their rear tyres on the outer edges. Mine was flagged at a service as being 2.0mm and wanting changes and his at an MOT as an advisory (albeit at a tyre fitter so you'd expect it?).
Both sets look like they've got loads of tread left (I'll measure tomorrow but I'd guess 5-6mm) across the tyre apart from the very edge. Would a 4 wheel alignment fix this? I have tried searching but got lost in the varying threads on tyre wear and switches to non RFTs...... Both cars are on Bridgestone RFTs. Just doesn't seem right to be thinking about junking tyres with that much tread on 90% of them! |
08-21-2013, 02:00 AM | #2 |
Dieseasal
204
Rep 6,881
Yes it will. Simple answer.
As long as they dial your camber back, which not all places can or will want to do especially on the front
Previously: 2003 Peugeot 206 1.6 8v | 2006 E90 320d M-Sport, 19" BBS CH, Full Ice-cold JL audio install, August 2010 Total BMW 6 page feature car. | 2003 Nissan 350Z GT Coupe 286BHP
Now:2010 E92 LCI 335d M-Sport |
08-21-2013, 05:41 AM | #3 |
Rep 298
08-25-2013, 02:51 PM | #7 |
Rep 1,113
Drives: M235i 6MT
On my E90, the outer edges wore really badly on the OEM RTFs but when I switched to non-RFT's they wore normally.
My current E92 hasn't worn the outer edge of the RFTs at all surprisingly. |
08-25-2013, 02:59 PM | #8 |
Rep 298
08-25-2013, 03:11 PM | #9 |
Rep 203
I went from RFTs with your problem to non RFT and it went away. I did notice the previous owner hadn't checked the tyre pressures and suspect this is what killed the outer edge as I keep tabs on mine regularly.
Got the geo done recently as a precaution as the alignment will always move from spec so worth getting it done yearly if feasible. |
08-25-2013, 03:12 PM | #10 |
Rep 2,216
Drives: E91 330d M Sport
Yes, it's well reported. By changing to non-RFTs the wear will even right out.
The outer edge wear is a *ahem* characteristic of the RFTs, recommended pressures and factory geometry.
Just how many Yorkshire sheep can you fit inside one exhaust?
08-25-2013, 03:28 PM | #11 |
Rep 1,113
Drives: M235i 6MT
Yep, just the tyre change. I have always been pretty religious about checking my pressures so I don't think that was a factor in my case.
Interesting though that the problem is absent on my new E92 on the exact same tyres though, not really thought about it until now. |
08-25-2013, 03:33 PM | #12 |
Rep 7,690
Drives: 335i SE Coupe Space Grey
I think you guys mean inner wear....
08-25-2013, 03:43 PM | #14 |
Rep 309
Drives: VW T5 Campervan...
I was thinking that too. I've owned RWD BMWs for 5 years now and every set has worn the rears on the inner edge. I expected that on my old Z4 as I was running excessive negative camber (-3.0 IIRC), and the e90's going the same way but with more normal neg camber. Both cars on non-RFTs.
Interested to hear how exactly tyres are wearing on their outer edge.
It's gone - no longer an e90 330i owner
08-26-2013, 06:00 AM | #16 |
Rep 15,858
08-26-2013, 11:30 AM | #17 |
Rep 65
Having the same issue here on both the original 16" with RFT, and then MV3s with RFT. The front outer edges are really bad, with the current fronts having around 5-6mm of tread over the rest of the tyre, but getting very close on the outside edge.
Just a bit of a concern because to anyone looking at it, a police officer on a traffic stop, it will look a lot worse than it should be. |
08-26-2013, 12:05 PM | #18 |
Rep 7,690
Yeah fronts tend to have outer wear....and the rears, inner wear due to negative camber.
08-26-2013, 12:22 PM | #19 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
I'm running 19" RFT on my car. The fronts are wearing evenly, though the rears are wearing on the inner edges....
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
