E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Adding oil cooler to US cars.
Reply
      12-06-2005, 12:25 PM   #1
Sho
Sho's Avatar
35
Drives: E90 325i 6-speed
It doesn't look difficult to add BMW oil cooler to US cars. Looks like only 4 parts involved.
2006 325i Sport - SSR GT7, Euro tails, Rogue Ikon muffler/w custom 3.5" piping, Painted OEM Splitters
2005 Toyota Matrix - Commuter
      12-06-2005, 03:34 PM   #2
E90Fleet
South Africa
1312
You are forgetting the tubing for the water
Its a water /oil heat exchager
There must be a reason USA cars ddnt get it
      12-06-2005, 03:39 PM   #3
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
We drive like old ladies in the U.S.
      12-06-2005, 05:28 PM   #4
Sho
Sho's Avatar
35
The water tubing is a 2 pieces parts. Replace the main water connector, so it has an additional location for the tube. Then install the tube that is between the main connector and oil cooler. Done.
There is no way that US id colder than Europe, so I don't see why we don't get the oil cooler.
      12-06-2005, 06:27 PM   #5
AW330i
AW330i's Avatar
Drives: Alpine White 330i
is this going to be diy material? If it is I am down I love OEM mods and I am not affraid of getting dirty working on my car... Anyone have any ideas on the cost of retrofitting this?
*edit* BTW is this all of the parts that are needed to do this?
http://www.realoem.com/bmw/showparts...19&hg=17&fg=05
      12-06-2005, 09:49 PM   #6
Sho
Sho's Avatar
35
http://www.realoem.com/bmw/showparts...55&hg=11&fg=35
All you need is #3, 11, and 12, and of course the oil cooler.
      12-07-2005, 12:14 PM   #7
Tierfreund
Tierfreund's Avatar
21
Drives: E90 330i
You donīt get it because you donīt need it. You simply do not have the opportunity to drive the car at max power output for a prolonged time. Heat buildup is far less when your top speed is limited. Accelerating (no matter how hard) will not cause too much heat buildup.
The Oil cooler is for European because even if a car is delivered to, say Ireland, thereīs a chance the owner will go to Switzerland for the holidays with the car, pass through Germany and give it the boot.
Only then do you need the Oil cooler.
Even when tracking youīl hardly need it. Unless your track is called Indianapolis. (But donīt got there if your running Michelin tires )
Sustained top speed runs really are the only thing youīd need an Oil coller for in the E90. And then probably only in the US spec 330. The US spec 325 is quite understressed and probably wouldnīt need it even for operations in Germany.
No, not THAT kind of tierfreund!
      12-07-2005, 01:02 PM   #8
smithex
smithex's Avatar
Drives: 128i
So US spec does not get the water /oil heat exchager?
Reply
e90post
