10-01-2013, 10:16 AM | #1 |
Rep 467
BMS Flex Fuel adapter on the F30. Easier than you think!
I just did mine over the weekend and this is very easy to do on the F30. This is an adapter that is added on to the JB4 Stage 2 so don't bother unless you already have that. The plug is on the back of the fuel rail and is much easier to get to than on the E90/92. All you have to do is take off the engine cover and a piece of styrofoam on the back half of the engine. The styrofoam can be a bit hard to get on and off. Mine ripped in half but it's not a big deal. You can see part of it still on the engine where it ripped. Other than that, just cut the 2 green wires in the JB4 harness and use a wire nut to hold them together.
This mod took about 15 minutes on the F30 platform. The AMP plug is labeled so finding the right hole (21) on it is a piece of cake. Just make sure that you put something below the two tiny nuts that hold the connector together before you unscrew them. One of mine fell off to never be found again. If you have an F30, don't let this mod scare you at all! If you follow the metal fuel rail back, the plug is attached to the end of it. You can see it is easy to get to. You can see the 1/2 of the foam piece that broke and stayed on the engine. That's not a problem. The other 1/2 still goes right back on. Here's a little closer shot with the BMS adapter plugged in showing how easy it is to reach. For $25, it's nice to be able to throw in 50/50 E85/91 and not worry about Map 2 giving me issues and it feels like a different animal compared to Map 1.
2011 335is Black/Oyster. 1 of 46 without moonroof (total of all years): JB4 E50 tune, gone
2013 335i M Sport JB4: Estoril Blue gone 2018 M4 ZCP: current 2023 X3M Comp: current |
10-01-2013, 10:34 AM | #2 |
Rep 1,997
Nice, I was just saying the other day that the BMS instructions left a bit to be desired. I'd like to see more pictures of the process but your last picture is better than any of the BMS ones of that area I think.
10-01-2013, 10:48 AM | #3 | |
Rep 467
There's no need to take apart the cowl to get to the JB4 in the F30 which makes it so nice.
10-03-2013, 11:54 PM | #5 |
Rep 1,400
That fuel rail plug is a mother f!er. Also the foam gets destroyed after you remove it a few times. Great power though. I don't recommend most people run above 40% E85 mix without sending logs to the mad scientist known as Terry.
10-04-2013, 12:03 AM | #6 |
Rep 1,591
I'm really surprised instructions and/or anyone is just simply splicing wires and reattaching the connections with a wire nut on a car.
I've always been hesitant to attach any wires that didn't just plug in without soldering. Cars move around too much. That's just me though.
-JustinNApproved
10-04-2013, 06:54 AM | #7 |
Rep 1,975
Thanks for posting this. I need to do this!
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
10-04-2013, 09:54 AM | #8 | |
Rep 467
10-04-2013, 10:22 AM | #9 |
Rep 467
Really? I thought the fuel rail was a piece of cake to get to. WAY easier than the E90/92. And yes, the foam sucks. I'm thinking of just keeping it off.
10-04-2013, 01:51 PM | #11 |
Rep 467
From what I understand on the other site, the N55 has pretty low maximum fuel trims. This mod allows that to be bypassed so the injectors can inject more fuel than the original DME would ever allow them to do. Since ethanol isn't as efficient, it needs that extra pulse width when you get above a certain ethanol percentage
10-04-2013, 01:55 PM | #12 | |
Rep 1,997
So running E85 on map 1 would have no effect (power) than running 93? What about map 2 since it's primarily for DPs? Maybe the tune is smarter than that and knows when there is E85 in the mix? |
10-04-2013, 02:02 PM | #13 | |
Rep 467
I actually just did a log this morning with the 50/50 mix on Map 7 and no other mods. Emailed it to Terry and he said it looks good
10-04-2013, 02:22 PM | #14 | |
Rep 1,997
What's the power feel difference between other maps with no other mods? I'd assume map 7 with that E85 would be at least equal to map 2 with DP, maybe more? |
10-04-2013, 02:41 PM | #15 |
Rep 467
Map 2 definitely feels stronger than map 1. I just put it on Map 7 this morning and only got on it once to log 3rd gear (Gotta love the 8AT in Sport+. no auto kickdown!) so I don't know the difference yet. In looking at the logs, boost was consistently a few psi higher on map 7 and AFR's looked about the same on both which is a good sign.
10-05-2013, 09:32 AM | #16 | |
Rep 1,997
I guess my question was how the E85 and different maps work. Is Map 2 (and flex fuel wires), which is adding boost over map 1 realizing the different fuel and utilizing the cooling features/higher octane of E85? The notes didn't seem to indicate that, but maybe it does. Just wouldn't want to be running Map 2 without DPs and E85 mix only if that isn't safe. It looks like Map 7 does definitely utilized higher octane fuel. I guess if I really understood what the tune and flex fuel wires were actually doing... Ahh nerd problems. |
10-05-2013, 09:49 AM | #17 | |
Rep 467
10-05-2013, 12:08 PM | #18 |
Rep 556
Drives: 2012 BMW 335I
I already got stage 2 and run map 2 all the time. I do not have the flex fuel wires yet. But basically if I were to upgrade with the flex fuel wires, I will be able to run a mixture of E85?
Also, if I were to upgrade the flex fuel, i would have my shop do the install. I do not trust myself with engine, wires and what not when it is not my specialty.. |
10-05-2013, 01:19 PM | #19 | |
Rep 1,997
I hope you have HFC or Catless DPs if you're running Map 2 though. |
10-05-2013, 05:19 PM | #21 | |
Rep 1,997
Did terry know you were asking about the F30? |
10-05-2013, 07:34 PM | #22 |
Rep 467
Run map 7 until map 5 is ready
