Interior paint pealing on steering wheel - anyone else have this issue???
10-25-2007, 04:30 PM | #1 |
BMW Enthusiast
20
Rep 161
Hey guys, the paint on the upper right hand side of my steering wheel is pealing a bit. I see a similar occurance happening on the driver door handle area thats painted. I've been using Z9 and Z10 to clean my entire interior.
Anyone else have this issue? |
10-25-2007, 04:38 PM | #2 |
Rep 203
Yes, my door interior door handle is pealing, looks more like a blue ink pen line. I might mention it when I take it for service....
Car handles so well, I always have to "stop short"
10-25-2007, 10:31 PM | #4 |
Rep 158
The problem you have is very uncommon for most owners, but can be a big issue if the conditions are there for it to occur. The problem is caused by a rubberized paint developed by 3M for automotive use that imparts a "Soft Touch" texture to the surface it is applied on. VW and Mercedes started using that stuff around 1998 and it lasts about as long as any non lacquer finish unless you have constantly moist sweaty hands or obsessivly clean your interior painted finishes with oil based preservatives like armor-all or any of the others that have emulsified oils or finish enhancers in them. Under those conditions the peeling can start in less than a year. VW gave up covering those under warranty years ago and although they still use that type of paint on their new cars, any replacement parts are now supplied in hard plastic moulded in color without any paint on them. Mercedes has eaten more interior panel replacements on the R170 series than I believed possible. If you can't get it replaced under warrany your best bet is to strip the remaining paint off the plastic so the look of peeling paint look goes away. I would strongly recommend that you stop using those types of cleaners on the soft touch painted surfaces of your car at once because they cause the rubberized part of the paint to break down and rot. Only a very small percentage of the population have the right combination of acids and salt in their persperation to rot the paint so none of the German car builders have seen a need to stop using those paints and I believe they all use the same paint even to this day.
If It Says Pratt And Whitney On The Outside
It Better Say Martin Baker On The Inside I saw a book titled "Sex for Dummies" and wondered why anyone would teach dumb people how to reproduce? |
10-25-2007, 11:02 PM | #5 |
Rep 774
Drives: E90 335i & E60 550i
My steering wheel trim also began to peel. My dealer replaced the piece without question.
Pure S2 Turbos | Vargas Outlets | RB Inlets | OEM SS Kit & Performance Steering Wheel| LCI Rear Conversion | Euro Xenons | RD Sport Quad Exhaust | Spearco Intercooler | Cobb V3 | MORR VS7 | KW V3 | H&R Sways | Mtech Bodykit | Vorsteiner CF Hood, CSL Trunk & Front Lip | Quaife LSD | Rotora BBK | GruppeM Intake | Forge UK DV | AR Design Catted DP's
10-26-2007, 12:16 AM | #6 | |
BMW Enthusiast
20
Rep 161
For now, I will stop using z9/z10 on the painted areas and only continue using it on the leather. |
10-26-2007, 12:36 AM | #7 | |
Rep 12,445
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT Current: '20 Shelby GT350|6MT |
10-26-2007, 11:53 AM | #9 |
Moderator
497
Rep 27,441
yes, it happened to me.
it's covered under warranty. i just had mine replaced recently, no questions asked. also had my drivers side door pull replaced because of peeling.
02-23-2010, 08:02 PM | #10 |
enter macho title here...
12
Rep 150
Do the dealers state a milage max for replacement?
I have two low milage cars and it's happening on both... 08's one with less than 20k the other with just over and the Dealer today said "it's not covered after 20,000 miles... |
02-23-2010, 08:23 PM | #11 |
Rep 1,938
The steering wheel on my 330xi MY2006 is OK, but the driver's side inner door handle paint is peeling. The area around the handle has a rubbery feel and the flakes feel the same way. So far, I have mentioned the problem to two dealers, who exhibited the expected low level of enthusiasm for fixing the problem.
02-23-2010, 09:15 PM | #12 |
Rep 283
same thing with my steering wheel, brought it in and they said it wasnt under warranty
but w/e im thinking of wrapping it in cf
2008 e92 335xi 6mt monaco blue with saddle brown interior.
List of Mods: BBS lm reps, CSL Trunk, M-Tech rear bumper,Muffler delete with DiMisa 4" Tips, 10% Tint, Black grills,Jb4, DCI, KW V1 |
02-23-2010, 10:32 PM | #14 |
Mad Linux Guru On The Loose
1130
Rep 5,400
Drives: 2008 335i Sedan, 2023 M3
Fellas, water is the ultimate cleaning agent you can find. Water dissolves almost anything out there and it will clean almost anything. You don't need any fancy cleaners, conditioners or chemicals. Simply warm clean water on a clean microfiber towel will clean anything from interior pieces, leather surfaces and carpets.
Want your windows to be so crystal clear that you actually cannot see the glass and at the same streak free? Grab an old newspaper, the rough, non-glossy paper is the best, and simply wet it with clean water. Then wipe your windows clean. No need for special glass cleaners... |
01-28-2011, 05:51 PM | #16 |
Rep 1,410
Drives: X3 M40i
i dont think this is covered past the 4year 50k warranty, even if its a CPO that still has warranty, it doesnt cover this stuff past 4 years
