11-29-2013, 03:01 AM | #1 |
Rep 181
Jb4 F30 / F32 - steering wheel control
I've been doing a lot of research on the BMS tunes for the N55 but there is one question I can't seem to find an answer to:
- Does the JB4 for the F30 and F32 allow the maps to be changed from the steering wheel controls like you could on the e9x ? |
11-29-2013, 07:22 AM | #4 |
Rep 923
Well now it's between map 0 and the last map you selected from the computer. No visual as they have for the N54 but now with the 8AT, the light on the shifter blinks 5 times if you select map 5, 7 times for map 7, once for map 1 etc. so there has been some progress.
Dash control should be available sometime in 2014. If you get the JB4 now you will be able to update to the latest version for free once the dash control is released.
GONE: '13 335i X-drive ///M-Sport | GONE: '16 340i X-Drive ///M-Sport | GONE: '18 540iX-Drive ///M-Sport | NOW: '20 X3///M
11-29-2013, 04:25 PM | #6 |
Rep 573
Drives: 2013 F30 335i 8SA M-Adaptive
OP, make sure you order the BMS usb cable when you get the tune, it'll let you change your map with the computer, take logs and update the firmware - it's basically essential
