is it good to use car cover when the car is still hot or wet?
10-26-2007, 09:53 PM | #1 |
Rep 257
I just wanna make sure if it is ok to do that.
TiAg 328i coupe with zsp, nav, ca, rearshade, power seats, black leatherette with burl walnut trim.
Placed order:9-16-06 production started:10-18-06 Production finished:10-24-06 waited at port of exit:10-25-06 Shipped: 11-01-06 Arrived:11-16-06 At VPC:11-21-06 At dealer:11-25-06 delivery: 11-27-06 |
10-26-2007, 10:02 PM | #2 |
Rep 7,246
i dont know about wet, since you shouldnt just leave your car wet in the first place. And if your car is dirty then your going to get the inside of your cover dirty as well.........basically, no, i wouldnt promote using a car cover with a wet car at all, makes no sense. As far as a hot car, it depends on what type of cover. If the cover is breathable and will allow some heat to escape, then it should be fine. If the cover is not breathable then you might want to wait a bit before you cover it up, although i dont really think your car is going to GIVE OFF more heat then it woul SOAK UP on a hot day. So id cover it up if its hot, to prevent it from getting even hotter from the suns heat. And if its night time and the car is hot, well it doesnt really matter since the cold of the night will cool everything off quickly anyway.
LTMW Widebody+1M front bumper+Slek CF Lip|M3 Hood|StopTech BBK|M-Sport Rear Bumper+DD CF Diffuser|Custom Recaro Seats|KW V2|BavX LS3|M3 Side Skirts+Custom CF Lip|BBS CHR 19x10.5+BBS Lugs|LCI Taillights|RD Sport Anti-Sway Bars|GIAC S2|ER Intercooler+CF Shroud+Charge Pipe|Tial BOV|Injen Intake|MS downpipes|Custom Exhaust|BMS Oil Catch Can|M3 DCT wheel+TiD CF Paddles|BMW CF Trunk Spoiler|Aluminum Pedals |
10-26-2007, 10:08 PM | #3 | |
Rep 257
10-26-2007, 10:52 PM | #4 |
Rep 530
You mean the car was just in the rain and you want to put cover on it while wet? I only know it is bad if you're going to leave it for a long time. I once washed a car and covered it, and left it for a few months when I was out of town, and ended up with rust problems in the mechanical parts.
10-27-2007, 01:12 AM | #5 |
Rep 3,593
wet usually implies dirty car, from all the crap on the road. putting a car cover on will make that grit rub against the finish.
basically, before you put a cover on, make sure the car is CLEAN. or else its like covering the car in fine grit sand paper. wind will make the cover move against the paint
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
10-27-2007, 09:10 AM | #6 |
Rep 2,384
Drives: W211 E350 4M MkV GTI 987.2 S
Some reason as why you won't put a hat on when your hair is wet.
07 E93 335i - Returned at lease end
09 W211 E350 4Matic Avant Garde - Blk/Blk, AMG pkg w/18". Sport Susp. F1 Asym. Debadged. 09 MkV GTI w/Leather & 18" Huffs. F1 Asym 10 987.2 S w/Leather sport seat, Sport Chrono, 19" Carrera S II wheels |
10-27-2007, 09:47 AM | #7 |
Rep 151
Car covers are only for clean, dry cars imo.
I have a flannel car cover for my old Corvette. I take the cover off, drive the car and then park it in the garage. It doesn't get covered again until it is clean. Same thing with your BMW. You are trapping moisture and dirt under the cover which is not conducivice to long paint life. In addition, once you take that car cover off, it is now "contaminated" with dirt and who knows what. So the next time you put your cover on your car, even if the car is clean, you are re-introducing that same dirt to your car. Imo, wax your car frequently and only use the car cover when it is clean and will be parked for extended periods of time. Gary |
10-27-2007, 10:42 AM | #8 |
Bad Lieutenant
233
Rep 3,517
I bought one of the Noah covers and even through hard rain, the car comes out nice and clean. Those covers breathe very well and can be thrown in a commercial washer on gentle. I wouldn't run out while it's raining and throw it on, you'll just cause a bunch on condensation under the cover and that isn't a good idea.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
